I have a 2000 X , and was wanting to put a plow on it. Any one have a plow, and if so which one. thanks in advance
2000 X with leveling kit and 315's,Isspro pillar guages,4"ATS exhaust, AFE intake, Edge Evo setting #3.Rear Hellwig Swaybar.
2003 E550 the work truck, with Power Edge
Any of the major plow manufacturers make a great plow, western, fisher, boss or Blizzard. I would go with at least an 8' plow. I had a meyer commercial 8.5 that did not affect the front too much that also worked well. Dealer service/parts are the biggest issue.
Howard
01X x-codes, swapped in Dana 60, rear add a leaf and air bags. Blizzard 810 power plow (expands to 10') The WORK truck.
05 GMC topkick 5500 4x4 152" wheelbase Duramax/Allison 11' steel flatbed Swenson stainless spreader, central hydros, Boss 10'V Leds Strobes
77 Bronco 302, stock looking except for the chameleon paint
A friend who has has worked at Muskegon Brake for 25+ years answered that question for me recently.
Boss is the best & WAY overpriced.
Western & Fischer are same company & excellent (He owns Fischer due to trip action) Western has poly blade as an option. Poly blades weight 80lbs more than steel, always look good, snow doesn't stick to blade & makes really clean/ smooth banks, if that's important. Has seen a poly blade in an accident, Blade bent into 90degrees. Replaced blade frame & bolted poly to it, like new!
These three have great mount kits that are almost invisible when blade is unmounted.
Meyer is cheap, lift motors are really cheap,I had one, won't buy another.
8.5 ft blade minimum recommendation.
DDD
__________________ My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
Brewpub, noticed you now have a blizzard plow,any pros and cons about the switch ( other than the 10 ft ). also on any of these plows is there any suspension work needed? ( i.e. springs)Only ask cause I have a leveling kit on my X , and 315 tires. thanks again
X springs were a neccesity, 600lbs of ballast and I had to put an add leaf in the rear because I was nose high. Price is about $1500 more for a Blizzard. If you are plowing just for yourself, any plow will work. I plow commercially with mine and can increase my productivity 100% with the Blizzard. It does weigh 1000lbs!!!
Howard
Brewpub, please help me out and explain what an " x spring " is [img]/ubbthreads/images/graemlins/shrug.gif[/img]and is it necesary with a leveling kit [img]/ubbthreads/images/graemlins/shrug.gif[/img] thanks again
Search and yea shall find. I could go on and on about them, but there is pages and pages of info on them here. If you front leveling kit added some carrying capacity you won't need the x springs. I would say you are fine as long as you don't go to a v plow or the blizzard.
Howard- you have a gasser, no? I can't imagine an 810 on the front of a diesel X. NJ- I'd go with an 8' or 8-1/2' "medium" duty plow. Not medium as in Medium-duty truck, but somewhere on the lighter end of commercial pickup plows. I have Western's 8-1/2' Pro-Plus. I REALLY like it, but with the weight of an X body and a diesel, I think it might be a bit heavy- likewise with a 810. If I were spending your money, I'd go with a western Pro-Plow 8 or 8.5. As far as mounts go, the Ultramount is above and beyond the rest- IMO. I can easily drive in and hook up in well under a minute.
Send me that spreader, howard!! [img]/ubbthreads/images/graemlins/grin.gif[/img]
2003 F350 CC, Short, XLT Sport (leather), 7.3PSD, Auto, 4x4. Homemade Tymar, Blizzard 810 Power Plow
NJ- I'd go with an 8' or 8-1/2' "medium" duty plow. Not medium as in Medium-duty truck, but somewhere on the lighter end of commercial pickup plows. I have Western's 8-1/2' Pro-Plus. I REALLY like it, but with the weight of an X body and a diesel, I think it might be a bit heavy- likewise with a 810. If I were spending your money, I'd go with a western Pro-Plow 8 or 8.5. As far as mounts go, the Ultramount.
Burner, thanks for your advise, but i checked today with a Western plow dealer and he said " they don't have any plow for a 7.3, only the V10 and V8". Blizzard dealer has one and wants $4500. for it installed, and I will need to X springs, from what I've read here.So I dont know what to do next. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Any idea's. thanks guys for your help and suggestions.
I'll not try to steer you away from blizzard by any means, but trust me- if you can carry a blizzard 810- you can carry any thing in westerns line. For instance- my truck (CC Diesel) is not available from Uncle Henry with a snowplow prep package. Does this mean it is incapable of plowing snow? Certainly not! It plows snow better than anything I have ever driven. However, there are alot of lawyers out there who don't want their client to take responsibility for anything, so if Ford doesn't want a plow on it, western opens themselves up if they say "We support installing a plow on it". My guess would be that Blizzard doesn't technically support putting an 810 on a diesel X either, but you dealer is willing to overlook that in order to provide his customer with what he needs.
For instance, I bought all the parts for my plow as though I was going to install them myself, then paid cash for the installation with a handwritten "Labor" receipt. This way, if a liability issue ever arises, I could never prove that they (the dealer, western, etc.) never endorsed having this plow on this truck. Warranty has never been a problem- I haven't needed it.
If you decide that you are comfortable adding 800-odd pounds to the front of your X, find a plow you like at a price you can afford and buy it. Pay cash for install or whatever, but get the plow you want, not just the one someone will sell you. I'd buy my Pro-plus again, but I'd also be willing to give Blizzard a shot at the title, too- either one is a good deal. It all depends on how much weight you want to carry- an 8.5' Pro-Plow is 715#, while a Pro-Plus of the same size is 821#. Blizzard doesn't list weights on their website, but it's gotta be every bit of 800#, if not closer to 850.
Bottom Line- the plow you want is the one you can get GOOD service for- even if it snows on a saturday night. (as long as it isn't a Meyer!! [img]/ubbthreads/images/graemlins/eek.gif[/img])
Burner,thanks for the advise.I think i will try anther Western dealer. The one I went to went to the Western web site and looked up a plow for my 2000 X w/7.3, and it didn't show any application for the truck, with that he said he couldn't help me.He also said the X front end must not be strong enough to carry the weight. I explained what I've seen here and that if the truck could carry a Blizzard plow it would be able to carry a Western plow.With that he said many dealers will put a plow on anything just to make the sale. So I will see if theres a dealer around here like that [img]/ubbthreads/images/graemlins/shrug.gif[/img].I will also try the cash deal to see if that helps. thanks again.
I've got a 8.5 ft. Western Pro Plow with back drag on the F250. Bought it when it was two years old used for $1,700 with mount and all wireing. Had to dish up $80 for the mounting nuts/bolts but installed it myself and saved a few hundred.
Used it when I had the 295's and no problems with stock suspension on the front. The plow only gets used for the driveway and ice fishing.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
The problem with any plow application guide is that Ford specifically states that installation of a snow plow is NOT RECOMMENDED. This is because the front blocker beam has to be unbolted and removed to install a plow mount.
This is a safety feature, and most do not want to mess with a safety feature.
Please note I do not say it is unsafe, I am explaining the plow manufacturer and Ford point of view.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
