Just completed a round trip to Memphis, some of the roads are not as great as they should be. But The New X samed to dipping down in the front, up in the rear.
Should I be thinking about twin shocks on the front?
Ken
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
You have discovered the one serious shortcoming of the X. The stock suspension is awful but fortunately is fairly easily correctable.
Firstly, change the shocks. The stock Ford shocks are, bluntly, dangerous. Edelbrock IAS or Bilsteins are the preferred shocks.
Secondly, change the steering stabilizer. The stock stabilizer is undersized and inadequate. Rancho or procomp both make a good upgrade. You will observe an immediate improvement.
Thirdly, add a Helwig rear stabilizer bar. Ford amazingly did not use a rear stabilizer for an 8000 lb. truck. Some members have also changed the front stabilizer to a heavier Helwig bar and have reported good results. I have not changed the front stabilizer bar because I am not yet persuaded that the effort is worthwhile.
In addition to the above changes, I also mounted BFG 295R75 16 tires to the stock rims. My X now handles very well. I just returned this evening from a ski trip using back roads that are heavily damaged from a deep frost. The X handled very well allowing me to drive hard over some terrible roads.
The only suspension modification still needed is the addition of 550 springs. I need the 1 1/2" lift so the my 295's won't rub the mud flaps and so the X won't bottom out as much on the frost heaves. If you look at your spring and bumper stop you will see there is only a 1/2" clearance! A greater clearance is obviously need.
If you make the changes outlined above, you will be very pleased with the improvement and your X will handle safely and comfortably.
Porpoise Effect? Nahhhh.... How can a Whale do that? [img]images/icons/wink.gif[/img]
Seriously, though, as noted - some good shocks are in order. The softer suspension on the X needs far better methods of control.
I'd go to a rear stabilizer bar too, but I go off road quite a bit and I'd lose some articulation. So, I just try to take it easy and remember that I'm driving a Whale.
Best to y'all [img]images/icons/smile.gif[/img]
Bilge Rat Association member with Ninja Wife
some of that effect comes from the long wheel base, mine does it on some roads that are heavily traveled over by big dump trucks. you want to have real fun try towing a 30' boat across alligator alley when you hit the dumb panther crossings that get beat up by heavy trucks
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
You mentioned upgrading several (Edelbrock IAS shocks, Rancho stablizer, Helwig rear stabilizer bar, and 500 springs) items on the X inorder to improve its sluggish handling. Could you enlighten us on what an aproximative cost would be to perform such a surgery?
I am about two weeks away from purchasing my very first diesel, and this has been one of my concerns.
Thanks to all of the members out there. This is by far the BEST site I have ever seen with loads of great information. I have been reading many of your posts for months now. I have never been so informed about purchasing a new vehicle in the past. Again, many thanks to all of you.
Just installed my new Bilsteins, fronts were a hassel, backs easy. Went out for a road test, so far a marginal improvement. I will put some miles on it tomorrow. The stock shocks were gas and didn't feel much different. Should get my Helwig stablizer in two weeks, think thats going to be the hot ticket. Size wise the Bilsteins looked a little smaller in diameter. Expected a bigger shock than OEM. I have been in the Auto bus. most my life, Owner/Operator, and have sold and installed shocks mostly Monroe& Gabriel. Seems like every time I installed a aftermarket it was bigger and finished nicer. -------------------------------------------Y2K1 White 4x4 LTD PSD. wing, dash kit, Ford outfitters rubber mats, rear liner, and "BILSTEINS"
Edelbrock IAS $50 each
Helwig Rear Stabilizer 145
Rancho Steering Stabilizer 55
295R75 16 BFG TA KO 189 each
550 X springs 260 (est)
I do my own installs. Labor amounts to about 5 or 6 hours. The springs will take me about 5-6 hours which is more than normal but I have never had smooth sailing with installing a set of springs. I will wait until warm weather arrives so I can at least knock back a few cold ones while I skin my knucles. [img]images/icons/laugh.gif[/img]
I almost did not notice it was your first post. I have not gotten use to the new look. Welcome to Ford-Diesel.com
Ken1, My 2 cents:
Here is what I have done based on info gleaned from this "group mind" of a website:
Rear anti sway bar. Helwig.
Front anti sway bar. Helwig.
Rancho RS9000 shocks (adjustable)(awesome).
Procomp steering stabilizer. $32.
BFG All Terrains. 285s. $801 mounted/bal. On stock rims.
These relatively inexpensive (except the tires!) improvements haave transformed the handling of the X. I ran with the rear bar only at first and then installed the front. Major improvement to have installed both the rear and the front.
Installation of all these items is relatively simple.
Rear bar 1 1/2 hours. (1/2 hour later to check installation and tune up. Helwig instructions skimpy.)
Front bar 1/2 hour. This is a replacement.
Front shocks 1/2 hour.
Rear shocks 1/2 hour. I am having problems with rear shocks which came from factory with defective bar pin mounts apparently.
SStabilizer: 15 mins.
Call Ryan at Super Duty Headquarters. (Sponser on this site. 480-633-2929.)
My next step is air bag rear suspension. (I have a heavy trailer.)
2 more cents: I believe my truck is much safer now with these suspension upgrades.
Ford could offer a heavy duty suspension pkg option?
POLR BR: I am interested in feedback on 550 springs. I have driven my friends F450 flatbed which has a very bouncy front end unless loaded. How will the X fare with those 550s? Please post results. Thanks.
And, thanks to all who have gone before who provided info which made my upgrades educated and easy.
Runk.
2006 F450 6.0 auto CC 4x4 12'contractors bed.
(SOLD) our reliable 2003 F350 Lariat 6.0-automatic, (purchased 7/03) CC, white, SRW, longbed, 4x4, Shell, Lumber Rack, otherwise stock (reflashed), C-betr mirrors, Bodiak frnt hitch, Type V rear hitch. Do alot of towing.
(Sold) our reliable 2000 Excursion V10.
Thanks for the site!!!
Kubota L4330 GST
Kubota U 25 Mini Excavator
CAT Skidsteer
'99 Airstream 31'.
12000# 20' equipment tag trailer.
'48 Chevy 3/4 ton stock.
CAT 12 99E Blade
12000# 12' dump trailer.
If you don't need to level front end with 550 springs, you should consider the Timbren load boosters. Hard cornering and stops are flat. Along with the Edelbrocks I don't think I need the Helwig up front. What are the diameters of the stock versus Helwig front bar? Do they change the end links? I would like to find some polyurethane bushing's for the front sway bar. Over frost heaved roads it does'nt porpoise, but the front end bounces a liitle. Do you think the rear sway bar would offer any advantage over my current set up? I don't do any heavy towing.
Did the BFG's help with the overall ride? I'm ready to dump the Firestone's(white letters falling apart). Thanks for any feedback.
Chile I also welcome you to the site and enjoy it and you can learna lot to. What could be better [img]images/icons/laugh.gif[/img] '
I am following this article closely as the stock suspension sucks big time! [img]images/icons/frown.gif[/img] I am trying to decide between the Ranchoes and the Bilstiens. Seems the procomp steering stablizer is the choice of most.
As far as the Firebombs go I think they should be recalled. Not only for tread seperation but also in wet weather they have the poorest traction of any tire around.
I have had Firestone on three other vehicles before and I will never accept another one with them. The POS areUNSAFE!!! [img]images/icons/frown.gif[/img] .
Ifeel that with the stock suspensions and the Firebombs our trucks are a little unsafe, thank goodness for their size and weight [img]images/icons/smile.gif[/img] .
Thanks for the good info. and keep it comming.
<font color="red">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~</font> SMILES and the best to all**Ed-<font color="red">RETIRED</font>**OINKING-BILGE-RAT <font color="red">FREEDOM IS NOT FREE ! ! !</font>
2005 LTD. X PSD 2WD FIBERGLASS RUNNINGBOARDS; SUNVISOR: REAR DEFLECTOR
<font color="00FF00">BENEFACTOR**<font color="red">NRA</font>**<font color="red">LIFER</font>**<font color="red">TX.ST.RIFLE ASSOC</font>**<font color="red">GOA</font>**<font color="00FF00">MEMBER</font>**<font color="00FF00">NRA/ILA</font>**<font color="red"> I VOTE ! DO YOU ? </font>**QUACK*QUACK ! ! !
<font color="00FF00">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~</font>
The 550 (X) springs made a big improvement in handelingand provided about 1 1/2-2 inches of lift in the front. Took about 4 hours. I haven't got around to doing the rear helwig install but it is soon in coming. Like PolrBear, I am not sure that I will need/want the front replacement. As outlined in prior posts, shocks/tires/steering stabilizer/anti sway bar are a must on these vehicles.
00 Excursion XLT 4X4 PSD Arizona Beige 3.73 LS BFG 295 KO's Westin Nerf Bars Fumoto valve K&N Air PP III Ranch Hand FER & Bumper X Springs Pro Comp Stabilizer IAS Shocks Dynomax Brite Box Dual By Pass and Amsoil Front to Back Thule Racks Photos
I looked at the Timbren web site and was quite interested. However, I want to get the front end up a bit for tire clearance and to increase the space between the bumper stop and frame. Besides, my X is leaning to the left and I think the left fron spring may be the culprit. After the snow melts, I will get out and measure the lean. Maybe I can get Ford to pay for the springs? [img]images/icons/laugh.gif[/img]
I've been following the suspension upgrade threads, and it seems most of you have 4x4. How many of these mods are applicable to 2WD? I am planning to order the Bilstein shocks soon, what about front stablizer and front and rear sway bars? Do I need them, and would they even fit on a 2WD? None of my driving is off road, but I do sometimes go down dirt roads with lots of potholes.
Ron
2001 PSD Excursion XLT 2WD, Medium Steel Blue, Comfort and Convenience Group, Limited Slip, Aluminum Wheels, Power Heated Trailer Tow Mirrors EBM2
Reputation is what others see, Character is what you do when no one sees.
I agree with PolrBr, I have Bilsteins, and Hellwig rear bar. I am very satisfied with it now. I have used Bilsteins extensivly here in the shop, and can recomend them without reservation. Expect to pay about $70/ea. I have not found the need for a steering stabilizer yet. BTW, I NEVER go off road, so my requirements may differ from those how do. Also, BTW, Thanks POLR BR for the tip on wiper blades. [img]images/icons/wink.gif[/img]
Ferraris do not break down, They just sometimes stop to be admired [img]/ubbthreads/images/graemlins/grin.gif[/img]
1970 Brabham BT29 Formula B Race Car Blue/black
1999 Ferrari 355 F1 Berlinetta Red/Tan
2000 Excursion Limited 7.3 2X4 White/Grey
2002 Excursion Limited Ultra 7.3 2X4 White/Tan
2002 Mercedes CLK 320 Blue/Grey (wife's car)
