Old 03-22-2005, 01:45 AM   #1 (permalink)
Power door locks???
Do our Excursions have auto-locking door locks? I am talking about the ones that self lock when you reach 15 mph (or whatever it is), and unlock when you put the vehicle in park???
I am asking because I just don't know. I bought my Ex used, and if it is supposed to do this... mine never has! (at least for as long as I have had it)
Thanks in advance!
CaliEx is offline
Old 03-22-2005, 09:39 AM   #2 (permalink)
Re: Power door locks???
my 2002 has it
1986 jimmy Buggy (RamJetGMC) 350RamJet th400 203ORD205on 42” tires d60/14bolt all locked and 200' of dom tube the offroad truck <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
2002 X 7.3 tow rig Excursion Limited Ultimate mods Green air filter, 3 gage pillar install,Tru-Cool Max TR cooler,FS-2500 Bypass Oil Filter coolent Filter,WW,tag,X overhose,X-code springs,F350 blocks,Banks 4" Monster Exhaust, AIC,programer, CB-cobra, Fumoto valve & a flux Capacitor <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
http://community.webshots.com/user/ramjetgmc
RamJetGMCaol.com
Zapped277 is offline
Old 03-22-2005, 09:58 AM   #3 (permalink)
my 2002 has it
I forgot they did, It is a feature you can turn on and off via the keypad as I recall
Bruce
Bruce1954 is offline
Old 03-22-2005, 01:38 PM   #4 (permalink)
My Photos: (10)
Or the computer. 2000 had a problem when this was active the windows would roll up. So they cut it off dew to the hazard of children getting hurt by the window going up.
j_apetersen is offline
Old 03-22-2005, 04:21 PM   #5 (permalink)
CHPMustang's Avatar
Cali our 2002 also has the auto lock feature and it should be a standard with the Excursions,I haven't heard of one yet without but I'm sure someone will chime in [img]/ubbthreads/images/graemlins/wink.gif[/img]
Once we put it in drive they lock.
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 03-22-2005, 09:45 PM   #6 (permalink)
On my 00 X it dosen't have this feature and it can't be programmed in through Ford. I think they started doing this when the dash clusters changed in 02. When I installed the Crimestopper remote start it had the option to program it in so I did and like it.
FMT
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-23-2005, 04:39 PM   #7 (permalink)
My '01 doesn't have it, I bought it used so don't know if it CAN be done.
-Chris
2001 4x4 Limited X PSD
Chromed SuperDuty grille, HeloMaxx8 17x9,BFG315/70/17,Edge 3' leveling,
Hellwig rear sway bar, AIS intake, PowerElbow, 4" Monster Exhaust, Aeroturbine,
Banks Big Head actuator, Banks Compressor Wheel, Banks Transcommand,
Tag's I and II (and love'm), Hx crossover, 2003 headlights, Bilstien shocks, Rancho stearing stabilizer,
203t-stat and billet housing, and Edge Evolution, 24" PIAA wipers, intake heater delete,
Garmin Street Pilot 2610 GPS
<font color="red"> New BTS trans</font><font color="#OOFFOO"> LANDYOT radius rods</font>
"If you don't get everything that you want, be thankful of the everything that you don't want that you don't get !!!"
drchris1024 is offline
Old 03-24-2005, 01:05 AM   #8 (permalink)
This 01 doesnt have it [img]/ubbthreads/images/graemlins/shrug.gif[/img]
'01 PSD 7.3L Excursion Limited EBM1, 8.5" lift, rear Deavers, 37" PJs, 16x10 Black Rockcrawlers, ORU dual shock hoops, Rancho 9ks all around, Magnaflow T304 system w/5" tip, FTVB w/50/50 mix regular Mercon/Mobil 1 in trans, Mobil 1 PS flush, Tri-pillar loaded w/Di PriCols (EGT,trans, boost), TS 4 pos. switch chip, ConFerr Rack, Cobra CB, TT/sig mirror conversion, 170 hi-amp alt, Hi Lift equipped, UltraDuty rearend cover w/Mobil 1 syn. w/OE friction modifier, Hutch/ITP intank mod, 2 Micron Dahl PrePump, FPR Jack shim mod@ 70psi, 203 deg T-stat & billet housing, Hawk pads, Centric rotors, Valvoline synthetic brake fluid 105.5k so far...
Recent mod: Dieselsite Coolant filter 4/21/05 @ 1100 @72 degs. F ambient temp ;P
Currently sittign in the driveway with a blown up tranny
Dirty X
Clean X
Vindicator is offline
Old 04-10-2005, 02:40 AM   #9 (permalink)
I believe most of them have it....even my 98 XLT Expedition had it, but there is an issue with the door sensors being flakey. When this happens, the auto-lock is the first to go. Next, you might see issues with the interior lights staying on for extended periods of time as well as the door ajar staying on longer than normal. I have a friend with an Ex and he has had the issue as well as another with a 99 F150. Its about $75 for labor.
jvanholten is offline
Old 04-10-2005, 02:59 PM   #10 (permalink)
My used 02 locks the doors, but does not unlock the doors automatically. This is very annoying when you have passengers in the back. Once you stop and get out they are left locked in.
Are they suppose to unlock? If so how can I program mine to do that?
A1980GMC is offline
Old 04-28-2005, 11:12 PM   #11 (permalink)
My 01 doesn,t have autolocks either. Must be 02 and later but none have auto-unlock. You just pull the door handle and it mechanically unlocks that door individually. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2001 X Limited 4x4 PSD,BFG M/T KM 285x75x16, Blown trans 24K,25K,52k X-codes w/F-350 rear blocks, Western Diesel 3Pod A-pillar gauges,Hellwig sway-bar,RS9000X,Dark Satin Green
1973 K5 Blazer 383stroker,TrickFlow alum.heads,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,, 2003 Mastercraft X9
boomboom is offline
Old 04-29-2005, 07:04 PM   #12 (permalink)
My 01 has it. But it's a part of the security system that came with the truck. 5 seconds after the key is turned on, the doors lock.
As soon as the key is turned off, they unlock.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
» Sponsor Links
»Garage Storage and Cabinets
