Old 01-31-2006, 10:17 PM   #1 (permalink)
power window problem....won't fully open
My drivers window is slow to open and binds/stalls at about half way. If I push on it, it will continue to fully open. But it closes at twice the speed without binding, even from full open. I changed the motor and sprayed some lube on the scissor mechanism and tracks, but still won't fully open without help. Any suggestions/cures?
cody726 is offline
Old 02-01-2006, 06:09 AM   #2 (permalink)
Location: Lumberton, Republic of Texas , Hardin County . and US of A
Re: power window problem....won't fully open
ON my previous Y2K X mine started doing that. I took the inner panel off and it was one of the hollow nuts that holds the track had started backing off. It miss aligned the arms and would start to stick. . You did not say what year model it is. If I remember right I had a screw inside where the courtesy light is at the bottom of the door. There was another one I think under where the switches are. They just pop out from the front I think. All the connectors have to be unplugged, but they are polarized so they will only fit the correct connector. There may be a screw in the door handle cavity and down on the right bottom of the the door. Heck it has been three or more years since I did that. When you figure out where all the screws are and get them removed the panel lifts straight up and comes off easily. I don't know if my 05 X is the same or not. It is not a hard job to do. While I was at it I took a can of silicone and put the wand on it and did all of my tracks. Did the windows ever work better. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
If someone has a better memory than me chime in or know for sure.
[img]/ubbthreads/images/graemlins/crazy.gif[/img] Ed [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
<font color="red">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~</font>
SMILES and the best to all**Ed-<font color="red">RETIRED</font>**OINKING-BILGE-RAT
<font color="red">FREEDOM IS NOT FREE ! ! !</font>
2005 LTD. X PSD 2WD FIBERGLASS RUNNINGBOARDS; SUNVISOR: REAR DEFLECTOR
<font color="00FF00">BENEFACTOR**<font color="red">NRA</font>**<font color="red">LIFER</font>**<font color="red">TX.ST.RIFLE ASSOC</font>**<font color="red">GOA</font>**<font color="00FF00">MEMBER</font>**<font color="00FF00">NRA/ILA</font>**<font color="red"> I VOTE ! DO YOU ? </font>**QUACK*QUACK ! ! !
<font color="00FF00">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~</font>
H ED S is offline
Old 02-01-2006, 06:33 AM   #3 (permalink)
It's a 2001 X. I've had it all apart, sprayed the silicone and changed the motor. Didn't see any screws loose. May need to take a closer look.
cody726 is offline
Old 02-01-2006, 07:05 AM   #4 (permalink)
Cody what I am talking about is those stamped nuts . Mine was about a 1\3 of the way off. Hope you find the gremlin . It was on the inside about the middle of the door and was one that that held the part that allowed the part that goes up. It would lean to the outside and bind. Dang it I could lay my hand on it but my terminology sux as to what to call the parts in there . hehe
Good luck [img]/ubbthreads/images/graemlins/crazy.gif[/img] Ed [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
H ED S is offline
Old 02-01-2006, 08:08 AM   #5 (permalink)
My 01' X does the same thing, when you figure it out let us know,
Thanks,
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 02-01-2006, 08:28 AM   #6 (permalink)
I haven't figured it out on my 01 either, other than the fact it seems to be a widespread problem. When mine starts doing it, I just spray WD40 up and down the tracks the window rides in. From the top of the door down, front and rear tracks. Then run the window up and down a few times, and clears it up for a month or so, then it's time for another spraying.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 02-01-2006, 09:00 AM   #7 (permalink)
Dave go to Orilly's parts house. They have a dry Teflon spray that does not attract dust and it would last longer to. Expensive though DuPont makes it. Good stuff. That is the blue can.The orange can has a combination of Silicone and Teflon. That may be better [img]/ubbthreads/images/graemlins/shrug.gif[/img] but I imagine it would leave a film.
H ED S is offline
Old 02-01-2006, 06:30 PM   #8 (permalink)
THIS STUFF works great for sticking or slow moving windows and will not wash off. You need to remove the door panels and apply it to the slides on the tracks and the window runs. Your local Ford dealer should have it in stock or could order you one.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 02-01-2006, 09:00 PM   #9 (permalink)
Thanks for all the info. I should have felt around up inside the door some more while I was replacing the motor, but I was sure that was the problem. I'll dig into it a little more on Sunday before the Steelers get their 5th championship!
cody726 is offline
Old 02-01-2006, 09:18 PM   #10 (permalink)
MotionMan's Avatar
Speaking of windows, I have been in maybe 10 different Xs and tried the windows, mine are 3x's as fast as every one I have seen, and I try them all, even SD PUs are slower. I have an 03 if that matters but man these are fast. I guess I am lucky, I will hit 100,000 miles in about 2 weeks and all I have had to fix was a door lock but that was the stereo installers fault. My reverse sensors don't work but I am used to that now and don't care. Oh, the plug for the block heater just went but I replaces it with speaker wire. [img]/ubbthreads/images/graemlins/smile.gif[/img] Just kidding, I did have to replace it though.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
» Sponsor Links
»Garage Storage and Cabinets
