Old 03-03-2005, 10:59 AM   #1 (permalink)
Predicament
I am planning a trip across the country this summer. We will be pulling a 32' travel trailer. (approx. 7k) There are 5 of us. (2 adults and 3 kids) We will NOT be hauling bikes, dogs, etc.. on this trip. :~> However, we will be going through WY, MO, CO, UT, and the North Carolina mountains on this trip. Our Excursion has almost 100k miles on it. I KNOW the engine is good for the trip, my concern is the transmission. We are not having any issues yet, nor do I anticipate any, BUT...
I use Mobil 1 in the transmission. This is my wifes truck, so it is driven on a daily basis. And not driven hard. It has never been "offroaded" on purpose :~> No lifts, no mods(except for the addition of shocks and a sway bar) , correct size tires (265 lt ms)
Should I be too concerned or just go and have fun? Any suggestions for what I could do BEFORE we leave to help head off any problems? We have towed many times with the truck, and it does a good job. I was reviewing out route the other night and noticed that some of the elevations are in the 7k to 8k range. WOW !!! It is 320ft above sea level here where I live in NC :~>
Any thoughts appreciated,
greg
GregW is offline
Old 03-03-2005, 11:31 AM   #2 (permalink)
MGX
Re: Predicament
Are you up to date on your fluid and filter changes? If so I wouldn't worry about it. If you really are concerned about it, take it into a good tranny shop and tell them your concerns and to look it over. It certainly won't hurt anything to put in a new filter and have the fluid completely flushed before the trip. At worst, go ahead and put in a new Torque Convertor as these seem to be the Achilles heel of the system.
Marc
2000 Excursion Ltd 2WD, Build Date 9/30/99, Oxford White, Medium Parchment Leather, 6 disk CD Changer, 3.73 LS, Magnum Deflecta-Shield, Vent Shades Ford Rear Air Deflector, AC Mod, Home Made Tymar, More to come sooner or later!
Let us put an end, once and for all, to this discussion of what a good man should be - and be one. -Marcus Aurelius-
Politics is the art of looking for trouble, finding it, misdiagnosing it, and then misapplying the wrong remedies. -Groucho Marx-
MGX is offline
Old 03-03-2005, 12:10 PM   #3 (permalink)
CHPMustang's Avatar
Re: Predicament
A big roadtrip pulling a 32' crosscountry during the heat of summer thru mountains and all I'd surely upgrade the Transmission Cooler to one from a V10 Excursion or go with a Tru-Cool Max from Dieselsite,both upgraded coolers will give outstanding results based on owner feedback [img]/ubbthreads/images/graemlins/cool.gif[/img]
Don't forget to backwash the fins of the AC condensor,Intercooler and Radiator for maximum cooling effect.
Perhaps adding a Bugscreen wouldn't be a bad idea either [img]/ubbthreads/images/graemlins/wink.gif[/img]
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 03-03-2005, 01:08 PM   #4 (permalink)
Re: Predicament
What year X is this? Some of the earlier 2000s had no transmission oil cooler in the bottom of the radiator. I recommend to check for that and also recommend to install a bigger Air to Oil trans cooler. The V10 cooler bolts right in and is around 20% bigger that the diesel unit, go figure. I had to do this to mine and it helped out considerably. These are the build dates for this radiator cooler problem Super Duty F-Series vehicles equipped with a 6.8L or 7.3L engine built 1/5/1998 through 2/6/2000, and 2000 model Excursion vehicles equipped with a 6.8L or 7.3L engine built 7/1/1999 through 2/6/2000.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-03-2005, 01:23 PM   #5 (permalink)
Re: Predicament
Thanks for all the info so far. This is a 2002 Excursion. 4x4, has the towing package. i like the bolt in option of the V10 cooler :~>
greg
GregW is offline
Old 03-03-2005, 01:38 PM   #6 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
Re: Predicament
[img]/ubbthreads/images/graemlins/wink.gif[/img] Quit worrying and enjoy your trip! BTW, if I had to do my mods over again I would probably get gauges first...these could really help you monitor your tranny temp. and pyro. to really be safe and not overheat it...plus they look cool [img]/ubbthreads/images/graemlins/smokin.gif[/img]!
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 03-03-2005, 02:01 PM   #7 (permalink)
MGX
Re: Predicament
OH POOP! Mine was built in 9/99. What do I look for to tell if I have a cooler or not? Where did the tranny lines (hence fluid) go to then?
Marc
MGX is offline
Old 03-03-2005, 05:44 PM   #8 (permalink)
Re: Predicament
Service the trans if it needs it
See this link for some addatives and why I use them
Link to Trans addative info
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 03-03-2005, 06:36 PM   #9 (permalink)
Re: Predicament
Look at the lower tank on the engine side of the radiator, if there are transmission cooler lines attached, the upgraded radiator has been installed. You will always have the air to oil cooler behind the AC condenser. If you look down where the hood latch is mounted on the radiator support you will see the air to oil cooler.
Excursion Pics
Old 03-04-2005, 12:57 PM   #10 (permalink)
Re: Predicament
i think you got some good advice on this i like the Tru-Cool Max cooler ( i have this on mine ) but at 100000 miles have you changed your CMP yet ?? change it or bring 1 with you and some simple tools
1986 jimmy Buggy (RamJetGMC) 350RamJet th400 203ORD205on 42” tires d60/14bolt all locked and 200' of dom tube the offroad truck <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
2002 X 7.3 tow rig Excursion Limited Ultimate mods Green air filter, 3 gage pillar install,Tru-Cool Max TR cooler,FS-2500 Bypass Oil Filter coolent Filter,WW,tag,X overhose,X-code springs,F350 blocks,Banks 4" Monster Exhaust, AIC,programer, CB-cobra, Fumoto valve & a flux Capacitor <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
http://community.webshots.com/user/ramjetgmc
RamJetGMCaol.com
Zapped277 is offline
Old 03-05-2005, 02:50 AM   #11 (permalink)
Re: Predicament
Any thoughts appreciated, greg
What is your route through Utah? Nastiest thing we have around here is Parley's Summit on I-80 a few miles east of Salt Lake City (elev 4200'). 7016' is what the sign said as I drove past last week. I tow over it several times a year, pulling either a 25' travel trailer or a jeep on a flatbed (6500lbs). It is avoidable, if you are coming from I-80 and heading north then you can take I-84 to I-15, and vice versa.
Oddly enough, that's the route that I take test drives on in vehicles that I'm really serious about. I've driven a couple X's over that, and they don't even downshift.
Get a tranny cooler and a tranny gauge if you are worried.
Give me a honk as you're comin' through.
Brett (in Draper, just south of SLC)
[img]/ubbthreads/images/graemlins/laugh.gif[/img]
'02 PSD X Ltd 4x4 "the new a-burbit" - Noah, 2 1/2. Corrected (V-codes, Ride-rite's with a Bruce inspired tank, Hellwig Anti-Sway) dvd/vcr, 315's, BHAF (Napa 6637), Walker BTM, pyro, DP 60high, 80high, 80econo, blah blah blah. Some kind of metallic blue with tan trim (now I need to paint my jeep hauler to match).
'81 scrambler...with a various assortment of parts.
'02 lemming minivan for my bride
Maverick4x4 is offline
» Sponsor Links
»Garage Storage and Cabinets
