Old 04-24-2005, 11:06 PM   #1 (permalink)
Prepump Mod
Read some older posts about the prepump mod. Went to a local parts store and asked for 14" of Diesel rated fuel line. They sold me a piece of "fuel injection" hose, and said it would work with diesel becuase it was made for the high pressure. Just want to verify that this is true before I go through the trouble of putting it on.
Also, was wondering why all of the bubbles would not separate out in the fuel filter? Seems like the flow through the system is slow enough that they would. Also seems like these things would develop air locks, with the introduction of a bunch of bubbles in the system.
'03, 4x4,6.0 PSD, Aspen Green X, Limited, 4x2 rear window strut mod., Bilstein Shocks, Walker BTM, Stainless exhaust tip, 30mm Ford rear swaybar
scubudo is offline
Old 04-25-2005, 12:28 AM   #2 (permalink)
Re: Prepump Mod
Go back and get your money back, all you need is 3/8 inch diesel rated fule line, 14" should cost $1.25, The fuel line before the pump is not under high pressure
2001 F250 PSD, SC, 4x4, LARIAT, SRW, 158 WB, AUTO, 3.73, Camper Pkg, 6 CD changer, Rancho 9000SX shocks, Cooper 265x75x16 STT Radials, A/C heater core bypass mod, pre-pump mod, Code = NMC1 Tow a 2000 Komfort 24FS 5er.
procraft is offline
Old 04-25-2005, 09:23 AM   #3 (permalink)
Re: Prepump Mod
Actually, if memory serves you want 5/16" fuel line. I've heard of folks having air bubble problems with the 3/8" line...which defeats the whole purpose of this modification!
Tailgate
2000 X PSD Ltd, 4x2, 3.73 LS, DP Tuner 16 position chip, Autometer gauges, AIS intake w/ Zoodad, Tymar H/X, Walker BTM, Dahl 100 fuel filter, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil all-around, PSD Badging, Extra Tint, Bridgestone Dueler Revo A/T tires
Tailgate is offline
Old 04-25-2005, 02:20 PM   #4 (permalink)
Re: Prepump Mod
It's 5/16 internal diameter. It only cost a couple of bucks...so is it diesel compatable and will it work?
scubudo is offline
Old 04-25-2005, 03:27 PM   #5 (permalink)
rock_doctor's Avatar
Re: Prepump Mod
You got what you want.
The problem is that there are so many bubbles; it is not just a few big ones but guys who came up with this mod actually said the fuel looked milky becuase it was so aerated. Allowing the bubbles to pass into the injectors causes cackle and will actually pit the injector pintles.
Unfortunately, the lines are leaking more on some trucks and less on others so you may not see a change but you never know. You can get an air/fuel separator that allows the fuel to pool and the air to come out. They work very nicely but also cost a fortune.
I would suggest you use a pair of needle nose pliers to slightly stretch the inside diameter of the fuel pump side of the hose. It will make it easier to get it over the rib on the fuel pump inlet nipple.
Good luck,
mark
2005 Excursion w/ 6.0L PSD
rock_doctor is offline
Old 04-26-2005, 11:18 PM   #6 (permalink)
Re: Prepump Mod
OK,
I just did long search for prepump, air in fuel, and etc. and found no old posts on this mod. Except 12/28/02 when some pics of "air in fuel" were removed due to damaged files.
Anyone have a suggestion on where I can read up on this and whether I even need to??
2004 X.
Thanks in advance,
Mesu
Excursion 2004 4X4 Limited - PUEBLO GOLD - 6.0L T-C Diesel - 5-Spd Auto Trans -AM/FM Sterio In-Dash 6-CD - Rear Seat Entertainment - DVD - 2nd Row -Dual Bucket Seats - PWR HTD T-T Mirrors - 3.73LS Axle - T-Case Skid Plate - Thule Top Rack - SC Tuner
Veh. Built 7/16/03 Eng. Build date 6/27/03 by International - Purchase Date 9/1/03 Milage on date 6/9/04 = 15,000 11/15/04 = 26,890 4/19/05 = 35,639 12/12/05 = 49,810 8/29/06 = 63,750 3/27/08= 100,003 Rancho 9000 shocks F & R.
It is hard to take travel serious when every time you leave home you take an Excursion !
Mesu
mesu is offline
Old 04-27-2005, 12:28 AM   #7 (permalink)
Re: Prepump Mod
You are not finding any posts because they are in the archived forums you have to <font color="blue"> search here </font> and go to the 7.3 forums and search under the 7/03-3/05 dates forums. You should find tons of posts.
good luck,
mark
» Sponsor Links
»Garage Storage and Cabinets
