Old 01-08-2004, 04:09 PM   #1 (permalink)
Question about X & Towing
Hi,
Currently I Have a brand new Eddie Baur X that is all stock. I plan on using it to tow 7,800 pound trailer and possible heavier in the future. With it stock can it tow this and something a little heavier without problem because I have heard a lot of confusing talk about mod chips and exhaust systems and such. If you think that it needs something more to preform it's best please let me know cause I am so confused [img]/ubbthreads/images/graemlins/tongue.gif[/img]. Thanks a lot for the help.
2004 Eb. X, 6.0 PSD
New_Diesel_Guy is offline
Old 01-08-2004, 04:16 PM   #2 (permalink)
Re: Question about X & Towing
My only honest suggestion is shocks and rear sway bar.Check my signature,mine tows my aprox.8,000 lb. TT like a dream. [img]/ubbthreads/images/graemlins/grin.gif[/img]
My Photos
<font color="red">2002 EXCURSION, PSD, XLT Premium, 4X4, Medium Wedgewood Blue,8' Meyers E-Z Mount Snow Plow,14.1" rear LCD video monitor and DVD, FS2500 bypass oil filter, Mobile 1 synthetic ATF, Rotella T 5w-40 synthetic oil, Baldwin transmission filter, K&N filter charger with Zoodad mod., Banks Trans Command, Bilstein shocks, Rancho steering stabilizer, Hellwig rear anti-sway, XM Commander satellite radio, C-Bet'r convex mirrors, factory remote start, daytime running lights, Silverstar headlamps, "Xtra" reverse lights, Hidden Hitch front hitch receiver.Cabela's Winter Grill Cover by Fria</font>
1996 Ford Crown Victora P-71, white, blue cloth buckets, super clean and super fast.
2006 Subaru Forester 2.5X Premium(I highly recommend it in snowcountry)
2005 Gulf Stream Canyon Trail 29TEBH,with Reese D/C HP
JOE_M is offline
Old 01-08-2004, 04:24 PM   #3 (permalink)
Supposely mine came with a stock rear sway bar because it had the new towing package, but what type of shocks would you reccommend and how much $$. Thanks.
2004 Eb. X, 6.0 PSD
Old 01-08-2004, 04:26 PM   #4 (permalink)
I think you'll be very happy with it in that weight range. The only complaint I had with mine (stock) was that when trying to tow at 60mph in flat Illinois it would downshift at every interstate overpass. This didn't happen at 55 with OD locked out, or 65 in OD, but at 60mph it would. After installing an SCMT that problem completely went away.
The other stuff like springs/shocks, etc are all good. The swaybar sure makes it sweet.
Have a good one,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 01-09-2004, 08:01 PM   #5 (permalink)
My Photos: (20)
I towed a 41 ft TT (9940 loaded) with my 2000 7.3 4x4 Excursion and the only mod was Air Lift rear air bags and Bilstein shocks. I plan on installing F&amp;R Air Lifts and rear sway bar to my 2003 6.0 4x4 before I tow the 41 ft with it.
jogiba is offline
Old 01-10-2004, 01:51 AM   #6 (permalink)
My Photos: (13)
X and TT weighed in at 16,800. The X is stock, towed from Cali to Alaska...no problems at all.
Doug
1999 F-350 CC,4x4,LB Auto,7.3PSD,air bags. ES9000s,leveling kit,Monster Exhaust,trans command,gauges,Six gun,Big Hoss,Brush guard,Front hitch,lights,35-12.5-16.5 BFG All-Terrains.
2002 Volvo XC
1994 Taurus SHO
A bunch of toys!
Snug is offline
Old 01-10-2004, 10:28 PM   #7 (permalink)
My 03 Ex lmtd also has the stock anti-sway bar. I tow a fairly small load for it in a 19.5'x8.5' double axle basically empty enclosed trailer. Maybe 4-4.5k max. My only tow so far with it was almost all interstate and about 1200 miles. Mine has a pretty significant sway problem when passing semi's. The truck really wags it's tail hard at the truck/trailer swivel joint. This is a common problem with these trucks.
I'm still can't believe this problem. It's a 3/4-1 ton truck chassis/running gear and it can't haul a smallish trailer like that without help. I knew about the quirky motor going into this deal but I was caught off guard by the severe soccer mom'ing of the suspension. Neither of my recent 3/4 ton GM trucks (burb and HD2500) had this problem with the same trailer. Very disappointing.
I'll likely go to air shocks or air bags to fix the problem. I want to try one more tow with more pressure in my E rated tires first, though. I don't expect it to help much, though. You'll likely find you'll need to work on both ends and get an equalizer hitch to be comfortable towing.
John B
03 Ex Lmtd 4x4 6.0PSD
jejb is offline
Old 01-11-2004, 01:03 AM   #8 (permalink)
This is my third X and I would suggest just keeping it stock. I have gone both ways with a heavily modified 2001 7.3, but I bought the 04 6.0 just to leave every thing as is. I pull a 32 ft 9k trailer without any problems what-so-ever. I do run an equalizer hitch and double anti-sway brakes on the tongue. You will significantly overload the X trailer towing/weight limits before you run out of power, all the other add-on junk is for bragging rights.
2004 Ford Excursion 4x4 Eddie Bauer 04 6.0L B/D 10/24/03
2001 TrailBay 31BHSS W/Slideout
1964 Karmann Ghia Coupe
AXTINC is offline
Old 01-11-2004, 07:51 AM   #9 (permalink)
Are you running a WD hitch? It's curious that you get the sway with that trailer. Do you have more weight ahead of the axle than behind it? Just curious.
Have a good one,
Dave
2003 Kubota B2910
dmftoy1 is offline
Old 01-11-2004, 08:38 AM   #10 (permalink)
Youve got to understand where jejb is coming from. He loved his burb, he loved his dmax. He hates his PSD X, he has never made a post without faulting something on the X AND praising how his old burb or dmax was better (wait, I take that back, posted he liked the wheels on the X). Its amazing how he almost gets driven off the road towing a small 5k lb trailer, but just one post later someone states they tow something twice as big and heavy with no problems.
The only towing Ive done is about 100 miles with a 5 k lb car trailer and had no problems, no sway, no wander. The car trailer doesnt have the flat sides a box trailer does, Im sure that makes a difference.
989171 is offline
Old 01-11-2004, 09:25 AM   #11 (permalink)
I tow about 3000-4000 miles a yr. I tow on a average trip about 500 to 600 miles each way. The X is awesome when set up right. The problem is every one is a towing expert and every one else is wrong. My camper weighs in about 7500 lbs with a family of five in the X. I have a reece dual cam weight dist. hitch and a prodigy brake controller and highly recomend them both. Air up the tires on both vehicles, proper tongue weight, adjust the Rancho 9000x's to 8 or 9. I dont want to get in a peeing contest, I want the safest people and trucks on the road. If you have a 1/2 ton burb that pulls 10,000lbs stay the hell away from the east coast as I dont want my family and freinds killed. I think some towing problems also come from lack of paying attention to driving and your condtions in front of you!
I am always looking for a safer product or tips from others to make me a safer person and I thank all the posters for sharing there comments good or bad.
Scott
2006 f-250 black Harley Davidson #1909 6.0 CC LB 4" MBRP, AFE 2,08 TT mirrors,
birdman127 is offline
Old 01-11-2004, 09:33 AM   #12 (permalink)
I have a 2002 X that I regularly tow 6000 lb's plus another 1000 in the back cargo area with.
I did it bone stock for the first year and it was easy as pie
Then I added the Rancho 9000 shocks and the Superchips tuner and now it is even better.
2002ExcursionPSD is offline
Old 01-11-2004, 01:38 PM   #13 (permalink)
Anyone who states their X is not towing well don't have the right set up,or has the right set thats not set up correctly.Once I clear the city and get on the open road I forget the TT is back there.I keep the CB on to remind myself.Joe M. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
My Photos
JOE_M is offline
Old 01-11-2004, 06:26 PM   #14 (permalink)
No WD hitch. Shouldn't be needed with this light of a trailer with a 3/4 ton truck. I did not have any problems towing this same trailer with my other 3/4 tons so, as I say, this caught me off guard.
John B
jejb is offline
Old 01-11-2004, 06:34 PM   #15 (permalink)
wanabe has been chasing me around for a while now. I gather he's not happy that I'm not entirely pleased with my Ex. I won't apologize for my opinions and I'll stand by my experiences. I've owned several new 3/4 tons in the last few years and I call 'em like I see 'em.
I like my Ex overall. I don't "hate" the truck at all. But I'm disappointed in it's towing prowess, engine quirkiness, loudness and low power output. I was expecting the engine quirks so that's it's hard to hold that against it. I do regret having moved to the Ex over my 01 HD2500 LT CC dmax/allison in some ways but that's water over the dam. I just hope my experiences can benefit others that have open minds, unlike some of the posters here.
John B
jejb is offline
