found 2003 f350 diesel springs.taken off for lift kit.. are these correct one for my 2000 ex .. what is good price for all 4 used . thanks for all your help and patience..
2000 excursion limited 7.3 4x4 -"the black beast"- my traveltrailer tow vehicle.monroe reflex shocks,helwig rear swaybar,2004 front spring bumpstops,isspro gauges,walker btm muffler,diy 4486 intake,265/70/17s.powerslot rotors,hawk pads.dp-tuner 80 econo,80 tow,120 . 6.0 trans cooler.
. 2000 CREW CAB LONGBED 7.3 2WD 94000 MI - sold
Sounds good..check door sticker for V code fronts..$400+- all 4.
Check the door code they could be A codes
My sons Father inlaw has a 01 250 CC short box 7.3 with Vs and As so they are out there.
Bottom line is you need to know what you have.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
he sold truck-- so no door codes.. says it was 2003 f350 diesel , snowplow package,fx4 off road package... can someone send me the codes on the springs for the proper ones i need .. thanks andy
I am getting to the point of thinking about the spring work. Is there any other way to identify the springs other than looking at the door codes? I am surprised that there are not stamped codes on the spring packs identifying them.
2002 Excursion Diesel-Stock owned 3 years 203k miles
Planning upgrades with the following order: durability, milage, power: 203 thermostat, Cat ELC, AIS delete, DieselSite engine and intercooler boots,
2002 VW Golf TDI-Nearly stock +taller 5th gear, LSD, 50+MPG, owned since new, 205k miles
I am 6'5" so the Golf is know as the clown car
My very best educated guess would be IF it realy was a SRW 350 WITH the full snow plow package and off road then it had Xs in front and Bs in back with full variable rates on the bottom and the 250/350 overload on top.
So for the rears you should be good, just do Carys mod.
Xs [550 fronts] are to much for most
No or at least no one here has been able to figure this out over the last 8 years.
Bruce
Reason: update
In the same thread TSprGuy posted the weight capacities.
For a F-Super Duty Series Front Spring
W Code, Cap. 2,400
V Code, Cap: 2,200
U Code, Cap: 2,000
T Code, Cap: 1,800
S Code, Cap: 1,600
H Code, Cap: 2,250
X Code, Cap: 2,600
G Code, I don't have a listing for this codes for a F-Super Duty Series Front.
C Code, Cap: 1,780 2000- 2006 Excursion Code
B Code, Cap: 1,680 2000- 2006 Excursion Code
D Code, Cap: 1,980 2000- 2006 Excursion Code
2000 7.3L PSD Excursion
4" MBRP 409 Turbo Back
Hellwig Swaybar
Isspro EV, Overhead 3-Gauge Mount
300K and rolling right along
Ford AIS
6.0 Liter Tranmission Cooler
Does anybody know what the rating on a "B" code rear is?
I put 5200 lbs springs in the front of my x and now it is the rears turn. What I am looking for is basicly the same ride quility when mt as oem but when I put a trailer on it I want the springs to pick up the load without much squatting.
This on a 2000 x 7.3 with a 180'000 miles on it.
