Re: Which Rancho 9000's with x springs?
Go with the W springs. Your X will sit more level, and you won't find yourself having to compensate at the rear.
I got RS9266s and RS9267s on the advice of SuperDuty Headquarters for my X with X springs. They work great. Mine are all installed with the adjuster knob down. For best results (read: I forgot to babysit the installer), have them install the front shocks with one knob facing forward and the other facing backward. That way, if you turn your steering wheel all the way to one side (which side is left as an exercise for the reader), you'll be able to easily reach both knobs. Also, be sure to babysit the installer and make sure they install the rears with the knobs facing rearward (yes, one was installed with the knob facing front, where you REALLY can't reach it). Admittedly, I had everything installed at a practically Spanish-speaking-only shop, but it was quick and modestly priced.
