Old 11-01-2000, 03:22 PM   #1 (permalink)
Rancho RS 9000 shocks/stabilizer
Just had the local Sears store mount 4 Rancho RS 9000 shocks on my EX. The part numbers are 9266 and 9267. Cost was $67.99 each plus $13.99 each for installation. Total with tax was $346. Not worth getting dirty for less than $60 labor. Does anyone else out there have these shocks? Which of the settings 1-5 work best for you? I will be testing them over the next several days in the different settings but would like to get some feedback on what settings work for you front and rear. Also waiting for a mail-order RS5406 shock to replace the stock steering stabilizer. Any installation advice would be appreciated.
Y2K XLT 4X4 PSD black/grey, BF Goodrich 285/75R16D AT KO, RAM grille guard, billet grille,PSD badges, Black Armor liners, Rancho RS 9000 shocks, Hella 500 driving lights
ridiesel is offline
Old 11-01-2000, 04:58 PM   #2 (permalink)
Re: Rancho RS 9000 shocks/stabilizer
Good price on the shocks. I paid 72.99 from Summit but I installed them myself.I love my shocks. I love how you can dial them to fit your taste.
I have a front end replacement which is basically a steel pipe front bumper with steel push guard welded to it and it adds about 450# to the front end so I'm sure it makes a difference. I set my front and rear on 2. I think 1 would work on the front as long as you are on the highway. I tend to go from highway to county roads so 2 is a more universal setting for me. I tow a travel trailer with weight distributing hitch and I use 3 on the front and 4 on the rear when I am pulling it.
If you plan on going from on to off-road a lot where you need to adjust them frequently you may want to consider the remote changer. It rained here a lot the last two weeks and between towing and not towing and sometimes hauling ,it tends to get a little dirty crawling underneath to change them in the rain.
As far as the steering stabilizer, I love mine. The 5406 does not come with new bracket and hardware so you must relocate the OEM bracket. It is a little difficult as there are indentions in the steering link for the bracket so the u-bolts are smaller than the bar diameter. If you work with it you can get the stock bracket on in the new location but it isn't a cakewalk. Since $13.00 wasn't much to you for shock installation you may want to consider purchasing the Rancho bracket(5542-$23.99 from summit) or order the stabilizer kit which includes stabilizer and bracket(97488-$49.95 from summit) instead of just the stabilizer. I didn't order them but I like a good challange. Good luck with your toys.
00 Excursion XLT PSD 4x4,Ranch hand FER and rear bumper, 550 Front Springs,F250 rear 4" blocks,Rancho RS9000 Front and rear shocks and steering stabilizer,Hellwig rear sway-bar, Banks Big Head actuator, PAC 100/200 chip and 4" exhaust, K&N air/oil filter, 3 guage pillar (w/boost, trans temp, and EGT guages),BFG 295's
04 Excursion E/B 4x4
05 F350 Lariat 4x4 CC Dually
Texcursion is offline
Old 11-01-2000, 05:40 PM   #3 (permalink)
Ok am I missing something here went to 4wheel parts and at first they gave me the 5406 which seemed fine except it lacked the steel bushings for the rubbers, I call to see if they have any and they tell me I need the 5404, well it had one of the bushings and they gave me another. Now my question is I just dropped my stock stabilizer and replaced it with the Rancho 5404 and all seems fine. Is it because I was replacing and you guys are starting fresh?? Just want to be sure. Thanks
Dave
'00 Excursion XLT 4X4 PSD 3.73LS , K&N,WD,lighted running boards, overhead console/computer, leather,Edelbrock IAS,Hellwig Rear sway,Rancho RS5000 stabilizer, SPA Dual gauge EGT/Boost dash mtd, cd/6 cd changer, DEI Python 1500 ESP w/remote start and shutdown timer. And last but not least 4 Firechickens
'00 Excursion XLT 4X4 PSD 3.73LS, ATS 4R100 w/TripleLok TC, AFE, Edelbrock IAS, Hellwig Front & Rear sway,Rancho RS5000 SS, SPA Dual gauge EGT/Boost dash mtd, 4" exhaust w/Walker Big Truck muffler
excurstroked is offline
Old 11-10-2000, 06:07 PM   #4 (permalink)
Ended up using the #3 setting up front with the #2 on the rears. Best combo for the highway commuting I do combined with some weekend mud-bogging. Still waiting for a rancho stabilizer which my local shop mail ordered. Probably the best thing about the Rancho RS9000 shocks is that Sears gives them a lifetime warranty which includes all parts and labor costs. Will probably be replacing them every 30-40k at that price.
Best $350 that I've spent on this truck so far.
Hellwig sway bars are the next upgrade.
ridiesel is offline
Old 11-10-2000, 10:08 PM   #5 (permalink)
how many shocks will the remote changer control. I have quad shocks on the front of my f250.
How does the changer control install??
by the way, I have the quads at 2, and the rear at 3 (with velvet ride shackles in rear). But, that's on a 250.......
'03 Ltd, Mineral Grey, 6.0.
aces full is offline
Old 11-15-2000, 02:20 PM   #6 (permalink)
aces,
check out www.gorancho.com for more info.
The remote control operates 4 shocks total.
There is also a splitter system (RS9602) which upgrades to seperate front and rear adjustments. I think you are looking for the multi-shock kit (RS9606) which converts two additional shocks to remote control and is required for quad shock applications.
ridiesel is offline
Old 04-24-2001, 05:56 PM   #7 (permalink)
Just curious if anyone knows if or what the part numbers are for a 4x2 X's front end (assuming the rear is the same).
For the price of the RS9000 shocks, you could get Edelbrocks or Bilsteins...any pluses or minues, or is it just "preference"? I have had no experience with any of these three shocks manufacturers.
Any guidance will be appreciated.
Tailgate
2000 X PSD Ltd, 4x2, 3.73 LS, DP Tuner 16 position chip, Autometer gauges, AIS intake w/ Zoodad, Tymar H/X, Walker BTM, Dahl 100 fuel filter, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil all-around, PSD Badging, Extra Tint, Bridgestone Dueler Revo A/T tires
Tailgate is offline
Old 04-25-2001, 04:48 PM   #8 (permalink)
I found the answer to my own question...was able to get in touch with the Rancho Technical Support guys.
PART NUMBERS for Excursion 4x2
Front RS9272
Rear RS9278
I would love to hear anyone's experience with these if they happen to have a 4x2 truck.
Tailgate
Tailgate is offline
