Old 04-23-2003, 11:14 AM   #1 (permalink)
Rattling Radio/Dash
Anyone have an annoying rattle coming from the center dash area in and or around the radio? Sounds as if a tape was left in the ejected position in the tape deck. I've pulled the radio out, left it half way in, pushed it all the way in. No fix yet. Dealer can't seem to hear it. Imagine that. Thanks in advance.
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
IMartin is offline
Old 04-24-2003, 06:13 AM   #2 (permalink)
Re: Rattling Radio/Dash
I've got one that I haven't been able to figure out in the same area, but it's wierd in that it only happens when the weather is down near zero, and after the interior "heat" gets comfortable it goes away. Sounds somewhat like what you're talking about. Since it goes away I haven't done much to try to solve it.
Good Luck!
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 04-24-2003, 09:56 AM   #3 (permalink)
Precisely. I forgot to mention that it is much more pronounced/appearant during colder mornings. Like yours, mine seems to go away as the interior heat goes up. Sorry for you, but I'm glad I'm not the only one. I'll bet there are many more out there like ours. Dealer has tried 3x to fix. No luck. Right now I've got my radio about 98% tucked into the console. The sound engineer at FORD thouhgt it could be the little brackets that hold the radio in place and that they may not be exhibiting enough pressure.
IMartin is offline
Old 05-01-2003, 08:32 AM   #4 (permalink)
Pull out the radio, and look back into the opening in the dash. There are two screws that are above the radio that secure the plastic dash facia. Mine were not tightened at the factory. Dale
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
shamuex2000 is offline
Old 05-01-2003, 01:19 PM   #5 (permalink)
Thanks. I'll do that. Maybe that will help.
IMartin is offline
Old 05-01-2003, 03:31 PM   #6 (permalink)
I know I have a rattle when it is cold, but it comes from the slide out cup holder. Slide it in, or add/remove weight and the rattle goes away.
I drove mine for a couple of weeks with no screws above radio while wiring my remote start/alarm and did not notice any change.
Good luck
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 05-02-2003, 08:50 AM   #7 (permalink)
The other thing I noticed was that if you remove the large panel below the steering column, you will see a steel dash brace on the right side of the opening. There are two heavy ground wires on the right side of this brace that were loose on my Ex. Tightening them corrected a small rattle, and an intermittent radio issue that I had. Dale
Chicago MOB member.
Old 05-03-2003, 06:34 AM   #8 (permalink)
All good suggestions! I've printed the post for future reference. For the next week my X is going nowhere without a trailer full of house stuff destined for the new place! Can't afford to be taking her apart now!
Take care,
Dave
2003 Kubota B2910
dmftoy1 is offline
Old 05-03-2003, 04:10 PM   #9 (permalink)
Got the same dash buzz.
How do you take the radio face plate off? I want to check my screws.
jschira is offline
Old 05-03-2003, 05:56 PM   #10 (permalink)
Go to autozone or kragen (checker) and get the ford radio tool for about 5.00 or two piece of coat hanger grounded down to fit the four holes on your radio to unlock the head unit to slide her on out then check all the screws you want
Dan
2001 XPSD limited 4x4 with SCMT and K&N, 3.5" down pipe, egt, trans temp gauges, Catch-All floor mats.Clear cornering lights Mobile video system w/ dual 6.8" screen overhead w/ DVD player and 5" front monitor. Yakima roof racks w/ Load Warrior.Rancho steering stabilizer Tekonsha Prodigy brake controller <font color="blue"> AIS Severe Duty </font>
99.5 F-350 CC-LB-DRW 4" exhaust,<font color="blue"> SCMT 1705 80hp mode </font> ;<font color="green"> SP DIESEL Stage I </font>;<font color="red"> WICKED WHEEL </font> ; autometer phantom gauge, bilstein HD shocks; berlin tonneau cover,tekonsha prodigy brake controller--
1993 Mazda Red Miata- 30mpg daily commuter..Jackson racing supercharger, HKS springs, Tokiko shocks, Toyo T1-R tires
rxbike is offline
Old 05-03-2003, 07:40 PM   #11 (permalink)
Thanks. What have you got to do, push the wire into those holes until I pop a latch?
I got lots of coat hangers laying around.
Come to think of it, Lots of AutoZones laying around too.
jschira is offline
Old 05-04-2003, 09:52 AM   #12 (permalink)
Just stick the u shaped keys into both sides and the radio will release then use the keys to slide it out far enought until you cna grab the radio and pull out. Watch out you don't damage any wires/antenna cable attached to the back by pulling out too hard
Dan
rxbike is offline
Old 05-04-2003, 11:25 AM   #13 (permalink)
OK. Went to the parts store and bought the Lisle tool. $7.49. Works like a charm.
There are 100's of things back there that can be buzzing. Who knows what it is. I zip-tied all the wires that looked loose to something and tightened every screw that I could get to. Let's hope that does it.
jschira is offline
» Sponsor Links
»Garage Storage and Cabinets
