rear AC on 2002 excursion is not blowing cold air - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 07-11-2007, 11:54 PM   #1 (permalink)
My rear AC on my 2002 excursion is not blowing cold air, the controls on the ceiling work: fan control, panel/floor but the temp does not work.
I checked all the fuses on the inside panels: they are OK, except 1 that was for the secondary cigarette lighter on the front dash.
Is there a second AC unit?
a different fuse?
where should I start looking?
thx in advance
vreynaud is offline
Old 07-12-2007, 03:53 PM   #2 (permalink)
Re: rear AC on 2002 excursion is not blowing cold air
""ONLY A GUESS HERE???""""
There are two expansion valves [orfices]...
One for the front, another for the back....
Remotely possible the one for the back is clogged [plugged]
Down stream, from the valves it should be cold..
Don't ask me where they are....I don't know.. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Other than that...you could check the freon pressures
XS_SUV
Graupp is offline
Old 07-17-2007, 05:24 PM   #3 (permalink)
If the temp control knob does not make the air hotter or colder, you have a problem with the hot/cold blend door system for the Rear A/C.
Could be a bad rotary switch in the overhead, or a wiring problem, or a blend door motor problem, or a binding door itself.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 302k miles.
ExcursionPSD is offline
Old 07-19-2007, 11:50 PM   #4 (permalink)
Same thing happened to mine. The blend door or valve was the problem. The compressor was leaking as well, so I had that replaced at the same time. Also, they replaced the expansion valve. Total cost was $900. It works as good as it ever has, but that is not very good. Stop and go traffic it never really gets cool. On highway its fine.
2004 6.0L X 4x4. 4th row seat.
krdadlamb is offline
