rear brake rotor removal...god help me!!!! neighbors ready to kill me - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 07-26-2010, 01:51 PM   #1 (permalink)
Okay guys... how do I get these rear rotors off? I've tried penetrating oils, hammering, sledging, swearing, yelling, kicking....
what's the secret?
thanks
2001 Ford Excursion Limited 7.3 Turbonetics Ballbuster Turbo Spearco Intercooler AFE Stage 2 intake 4" Exhaust Stacked Tuners V code front leaf springs
tnuottila is offline
Old 07-26-2010, 02:42 PM   #2 (permalink)
DouglasH's Avatar
Everyone has said get a bfh and if that doesn't work get a bigger one.
Stuck rotor - any tips for getting the #@%#$ thing off ??
2004 EB Excursion. A few mods
DouglasH is offline
Old 07-26-2010, 11:54 PM   #3 (permalink)
lance1955's Avatar
Well beating in clock wise or counter clock wise motion from the inside. Beat on and do the same thing on the hub of the rotor. Your probably going to need a 5lb sledge hammer. I had a buddy that his were so Fing stuck after hours and hours of beating. I busted out the air chisel until I final got it deep enough and then took a had held chisel and split the rotor casing hub. Just on the top enough to relive the pressure. Came right off after that. We did this on both sides. So, if you run out of ideas you might have to go that route. I suppose if you dont have air tools, and your good with a sawzall then you could do the same method. The important thing is after you get them off hit the axle part where the hub sits with a high speed wire wheel. To get that rust build up off. I wish I saved the pictures of the rotors. They looked link sprocket gears where they had broke off from the beating they took. I ran into this problem on another tuck and I did the same method with the air chisel. Worked like a charm. I thought I would never have to do one like that again. Boy was I wrong. I imagine if I had a lift then you could get some real good swings on it
2002 Excursion 7.3L 200K+, After market tranny cooler, diesel site transmission filter kit, coolant filter kit and complete boot kit, bilstein shocks. Original transmission with mobile syn ATF
lance1955 is offline
Old 07-29-2010, 05:22 AM   #4 (permalink)
Did you adjust the parking brake shoes down?
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 35x12.50-17 Mickey Thompson ATZ, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120), Adrenaline HPOP, Coolant Filter, Amsoil bypass filter, Ford rear sway bar, 6 1/2" spring arch.
2000 BMW 540i, 6 speed, sport package, daily driver.
jnyost is offline
Old 07-31-2010, 10:35 PM   #5 (permalink)
Supporting Member
You'll have to take the hub off and lay the rotor and hub on the ground. Take a large piece of flat steel and place over hub, with sledge and one good blow will pop!
If your beating on it that bad, you might want to worry about your bearing in htat hub anyway. Plus its prob time for some new rear hub seals anyway.
03 X added
sold a very thirsty 350 4x4 cc long bed, all white, 06 KR
350 4x4 cc long bed, all white, 01
sold 350 4x4 cc long bed, drw, all black, 99
GRIFF350 is offline
