Is the rear bumper for an X the same as the one on the Super Duty? What about an aftermarket "Ranch Hand" type? Will one from a truck fit an X? Thanks.
Yes, the Ranch Hand will fit. The toughest part is taking the factory hitch off. It is attached with break-away bolts but we air chiseled them out...other than than, smooth sailing. We had to drill the holes for the back-up sensors, piece of cake. My Excursionator
1997 PSD-250HD, 4x4, 5 Speed, standard cab, downpipe, buried muff., 4.7 advanced, Baldwin open air element, Fumoto F-111 plug, Isspro pyro and manifold pressure gauge on pillar, Gulf Coast oil by-pass filter, M/T Baja Radial MTX's.
-SOLD- 2003 Excursion 6.0 Oxford white, Eddie Bauer 4x4. Turbo Lifesaver, Oil Guard by-pass, Fumoto plug, Rancho RSX'x up front, Rancho RS5410 stabilizer, custom rear air shocks, 30MM rear stabilizer, Radius-Rods by Landyot, Ranch Hand-front and rear, 5 IPF off road lights, Marinco heater plug receptacle, 305's Cooper Discoverer S/T on MT classic II rims, pillar pod with Isspro pyro, trans temp. & boost, V and F code springs.
"The polite society, is not one which nobody is armed, but rather one in which everybody is..." Robert Heinlein.
I am not quite sure what you mean by..."in the factory bumper they use that tapered collar so that option was out"
We used the same housing mounts that were in the bumper. Once we removed the sensors from their respective housing-collars, we pried them out (carefully)from the old bumper and re-installed them in the new one. Sensors went back-in and that's about it.
