I would like to as well.Every once and a while I go looking but have not found anything that I would use. Then again it's not priority for me, but I will find something.
DUNC
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
Now the LED bar that Jim had done is a definite Yes [img]/ubbthreads/images/graemlins/smile.gif[/img]
Bill
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
How was it mounting the ID bar? I was not sure there was enough clearance between the doors and the bumper.
Another post on this site had a link to a LED light bar that was also used as a brake light and turn indicators. I liked that idea since the ID bar is more in line with other people's eyes.
West Deptford, Gloucester County, Southern New Jersey
2002 Black Excursion XLT 6.8L V10 ( Pics) - Timbrens, 2WD Lift Gate Struts, PIE adapter, Cell Phone Harness. 2002 Ford Explorer - Wifey's ride. 1999 Sunline T24 Saturn 25' TT (Pics) - Every option avail at the time.
Thanks for the link obonaventure,it's got a a good price to match too [img]/ubbthreads/images/graemlins/cool.gif[/img]
Keep them mods coming! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Bill
I'm kinda curious if the install can be done without pulling the bumper to do the mounting and wiring.
I installed the 3 light id-bar when I replace both black stock bumpers with chrome ones, so we had plenty of room to work.
I looked at this before and after installing the bumpers and it seems like it could be done with the bumper installed, but it certainly would be a tighter fit.
What we had to do was notch the metal door sill (below the plastic valance) which supports the rear door catch, as well as notch out the plastic valance itself. Basically, we removed the 90-degree lip portion of the sill a little larger than the width of the id-bar. The plastic valance was trimmed to show the lights, but only wide enough so the 2 mounting holes on the id-bar wouldn't be seen. Next we notched the back portion of the bumper step tread so the id-bar would fit between the bumper and door sill with the lights being centered between the two as much as possible. This might be a little tight, but with a small dremel tool, especially with the flex-shaft attachment, it could be done.
The tricky part might be mounting a couple of brackets to support the id-bar. With the bumpers off, we welded a couple of 90-degree brackets to the underside of the metal door sill to allow the 2 mounting holes from the id-bar to bolt to. With the bumper on, you might have to drill a couple of holes from the top side, then fasten the brackets with nuts/bolts...or fashion something else to attach the id-bar to.
Then of course wiring it up...
Hope this helps...Jim
__________________ 2004 X Limited 4X4 (built 1/12/2004) 6.0L PSD · Black · 3.73 LS · PSD badging · 18" HD Wheels · Xenon airdam · Chrome front & rear bumpers · Chrome Stull grill · Chrome tow hooks · APC projector headlights · APC diamond clear corner lenses · Bilstein shocks · TT and Paddle mirrors · Donnelly auto-dimming mirror w/map lights & compass/temperature display · Cab lights · Rear 3-light id bar · Dual monitor DVD/VCR entertainment system · Rearview camera/monitor · Python alarm w/remote and low/high temperature start · Underhood insulation blanket & light · Husky molded mud flaps · Fumoto oil drain valve · Courtesy lights with clear/red lenses · 24" front & 18" rear wipers
