Old 12-20-2004, 03:11 PM   #1 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
Rear Diff./Pinion Seal?
OK, I'm under the X while doing the WW install this weekend and I notice fluid has blown onto rear underneath of X. On muffler, front of rear axle, back side of hubs, etc. Looks like it may have come from my rear pinion area...just in front of rear diff. where drive shaft goes into pinion? I noticed a very small spot a few months ago when I changed my VSS. How do I top off the rear diff. fluid? Do I have to go in through the VSS plug? There is a plug with a socket square fitting on the drivers side of the pumpkin about 1/2 way to 3/4 of the way up...is this the drain plug or fill plug or neither??? I really just want to check the fluid level before I get into big dollars to fix the pinion seal!! Is the rear diff. fluid flowing in the pinion area? Can someone explain this part/area to me and how I deal with my rerar diff. and fluid?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 12-20-2004, 03:43 PM   #2 (permalink)
Re: Rear Diff./Pinion Seal?
yes the fluid you are seeing is rear end fluid.
the plug you see with the square hole is the fill plug, a 3/8 ratchet and extension fit it perfect, rear ro be filled with gear oil until it comes back out the hole...
it seems to be a common problem with the x's for the pinion seal to leak...
1978 bronco XLT ranger, 4x4, hopefully soon to be an IDI candidate
1939 ford coupe, 351 cleveland supercharged, 33 x 19.5 mickeys out back, 700 + HP
2002 harley softail duece, many upgrades....
1972 ford torino, 351 Cleveland, AOD, in process
glennz is offline
Old 12-20-2004, 04:09 PM   #3 (permalink)
As long as I make sure I keep fluid level up back there will it generally be safe to drive it for a while like it is? I do not hear any gears and the X is running and shifting fine. I just spent a big chunk on intake, WW, AIH mod, gauges so I'm trying to wait a little while before dropping any more dough!!! I will not be towing anything heavy either...just everyday driving. Whatcha think honestly?
Jeff27 is offline
Old 12-20-2004, 04:36 PM   #4 (permalink)
I would keep an eye on the fluid level and you should be fine for a while. Remember the fluid is a sythentic ($) 75W-140 gear oil if I remeber correctly.
Hope this helps,
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 12-20-2004, 07:53 PM   #5 (permalink)
ditto, should not be a problem,
mine has leaked for about 1 yr now, and watch it, in the last year i may have put a 1/4 pint in it...
glenn z
glennz is offline
Old 12-21-2004, 01:12 PM   #6 (permalink)
I would get it fixed as soon as you can. I have found in the past that these pinion seals go from weaping to dripping very quickly, not to mention the mess. I found a shop in San Diego called Pro Gear that specializes in off-road vehicle diffs and transfer cases and had it done for $91. The stealer wanted a little over $200 as I recall. Look for a 4x4 shop as this type of fix is their "bread and butter" and the pricing is usually better. Also I have a Mag-hy-tec cover and when I installed the cover I set the fluid level to the middle of the dipstick with the vehicle on level ground. Then I checked it a few months later using the diff check plug and found that quite a bit of oil came out. If you have a hy-tec cover and set the level with the dipstick you might have it overfilled. It is possible that this condition caused my seal to fail early at 45k but others with the factory setup have had them fail early too.
-Bill-
NautiqueHauler - Black 2000 Excursion PSD 4x4, Helliwg Sway Bar (F&R), Billsteins, Husky mud guards and floor liners, Garmin GPS 2610, Bridgestone 285 A/T Revo's and a CPS in the glovebox!!!
Bill Tifft is offline
Old 12-24-2004, 09:24 PM   #7 (permalink)
I was told by a mechanic friend that this is not just in the X the other fords with the same rear end have this problem also. I replaced my own seal it was not a hard task to do and have had no leaks for about six months now. I was thinking it was going to be a pain so I kept adding oil till I couldn't stand the gear lube smell any more. I was told that the part that the seal rubs agenst can form a gruve and that mite need to be replaced but mine was fine.
I have a 2000 Excursion limited 4X4 7.3 still stock.
TerryGould is offline
Old 12-25-2004, 02:09 PM   #8 (permalink)
How did you do it? What kind of tools do you need? I hate paying the stealer.
Jeff27 is offline
» Sponsor Links
»Garage Storage and Cabinets
