The black trim piece on the rear upper door around the door handle has started to discolor. This is the piece about 3 feet long surrounding the door handle. Does anyone know how to take this part off? Is it screwed on somehow or double sticky tape or what? The clear coat has started to bubble and is getting worse by the day.
I would try taking off the lower trim on the inside of the door and see if there are screws holding it in. The shop books I have dosen't really show that piece specificly.FJF
2000 Excursion Limited 4X4, 5" Hypermax Exhaust,TS 4 Bank chip(D/P Tuner- stock,Tow,Econo,Race) A Pillar DiPricol Gauges (white face)Hellwig swaybar,Skyjacker stablizer,AFe Stage2, Slotted&cross drilled rotors,BB Turbo,Pioneer AVIC D2 <font color="RED"> *** ALL GAVE SOME, SOME GAVE ALL(FDNY 9/11/01)***
It is a separate part, when I had to have my back glass replaced I fairly sure the glass guy took that off first.
BTW don't break the back glass you can rebuild an axle cheaper [img]/ubbthreads/images/graemlins/depressed.gif[/img]
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
I think it just unsnaps straight out, but I can't remember how the local auto glass guy removed mine. That was why I suggested seeing them.
BTW, don't try to close the lower doors with the glass down. There is a little tab that sticks out at the outter top edge of the doors and just kisses the edge of the glass...just enough to shatter it. Replacement glass if you don't have comprehensive insurance is something like $2,300. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
i hope thats glass for the whole truck.... [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
My hinges are starting to chip and the next thing is rust. Thank goodness the doors are platic or they would rust, you would not beleive the rocks that bounce off trailers into the door.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
Afraid not!
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
No when I did my rear glass it cost $1100.00 I paid the comp ded.
List for the glass not including install was $2800 as I recal [img]/ubbthreads/images/graemlins/confused.gif[/img]
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
A year in a half ago the X was picked up with 104K miles. When it was time for it's first good cleaning I spotted a small piece of glass in the very rear of the vehicle. When the piece was held in front of the rear glass it looked the exact same. The next thing was to try to see if the key would unlock the rear door, no luck different door!!!
The original owner must have broken it.
BTW, it is a good thing the rear doors are fiberglass rather than metal. I won't get into any details but I watched a rather large guy run up and kick the driver side rear door just to the right of the hinges in the middle and his foot bounced right off the door!!! When the cops came I showed them the rather large boot print which was good evidence!!!
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
I guess we're all replacing liftgate glass. I had to do mine a couple weeks ago. No idea what caused it, a hot day, window kind of dirty, had just a thin crescent of glass missing in the upper center of the glass, but the entire glass was crazed and ready to fall into cubes. The cleanup was the worst part of the whole process. Glad to have a Shop-Vac
I did spend some time arguing with the first glass 'tech' over the phone about which tail door style I had. He was confused about the part where all Excursions have tri-doors with tinted glass. [img]/ubbthreads/images/graemlins/confused.gif[/img]
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
Just when I thought I was the only dummy who had absent-mindedly shut the the glass before one of the cargo doors..... it was amazing how that little tab sticking up from the right side door can so effectively spiderweb the entire glass. In Houston, it was only 1600 total at the dealership, but they got it done in one day.
