Old 09-29-2007, 06:34 PM   #1 (permalink)
My Photos: (11)
Rear DVD player went out, any suggestions?
My rear factory DVD player in my 03 Limited X went out, after using it a whopping 6 times in 4 years. What are my options? I would like to keep the factory rear console. Where can I buy just the factory DVD player? Is there anyone who sells a direct replacement? Any help would be appreciated. Thanks.
Mike
2003 X LTD,6.0L,Torqshift,4x2 (wife's toy)
Autometer Z-series Tranny/Boost/Pyro in Under-dash pod
Hellwig Rear Anti-sway bar
Stull Billet Grill
AFE Intake w/ Proguard-7
Magnaflow XL 4" Turbo Back Exhaust
20x8.5" MB Gunner 8 rims on Michelins 305/50R20
CobraMike is offline
Old 09-30-2007, 11:06 PM   #2 (permalink)
MotionMan's Avatar
Re: Rear DVD player went out, any suggestions?
How did it go out? I have the same deal but have had no problems. The wire harness is easy to get to. If all else fails they make units that could fit there with a larger screen even....plus at 1/3 the cost. You should be able to wire it in like the factory one, just take it to a good stereo shop, they can wire up anything.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 10-01-2007, 11:11 AM   #3 (permalink)
My Photos: (11)
We tried a DVD in the player and we get no picture. The dealer said there was some kind short, but nothing else. Pretty vague! I want to keep the console (with A/C controls) all stock so I really just need to replace (or troubleshoot) the DVD player itself. Any ideas?
Mike
Stull Billet Grill
Old 10-01-2007, 08:39 PM   #4 (permalink)
a new unit is about $1200. i checked because mine did not come with wireless headphones, and i wanted the version that did. in thee end, i added a wireless transmitter to my factory unit and it works like a champ.
if you are inclined, the whole thing is easy to remove. 6 screwws i think and then pull down on one of the corners. it has its own hanger system that will support itself while you unplug the harness connectors. there is a small, flat, thin cable going to the monitor, and basic ford connectors for the input and power. make sure everything is plugged together.
btw, when you put a disc in, does your head unit acknowledge that the dvd is inserted and trying to play?
good luck
Diesel horns make me smoky!
2003 Excursion Limited 6.0L as stock as they come
thesixcar is offline
Old 10-02-2007, 12:11 AM   #5 (permalink)
MotionMan's Avatar
Is the player spinning? if so it is a short path for the AV wires and it could be simple, you just have to drop the unit and see but I am at a loss if it is more than a loose wire or something simple when it comes to 12 volt. I would just pop it open and see. There are a ton of different configurations too, it could be a matter of being in the wrong mode. How about sound? Spinning ans sound are good. Are you familiar with the dash and back of center council controls? Just checking [img]/forums/images/%%GRAEMLIN_URL%%/whistle.gif[/img]
Old 10-02-2007, 11:36 AM   #6 (permalink)
My Photos: (11)
I do think it is spinning, and we do get sound. I will drop it later this week and take a look. Thanks for the help. I will let everyone know what I find.
Mike
Stull Billet Grill
Old 10-02-2007, 12:56 PM   #7 (permalink)
My Photos: (11)
Well I just dropped the unit down. I checked all the connections and all are properly inserted. I did not see any frayed or damaged wires. Everything was nice and neatly routed. The player does spin. We do get sound out. And the screen does come on. The picture looks like a scrambled picture, with a slight hint of color in the scramble. I am by no means an electrical expert, but is there anyway to test the cables? I would assume there is a problem with the cable going from the player to screen. Not sure.
Mike
Stull Billet Grill
Old 10-03-2007, 06:20 PM   #8 (permalink)
MotionMan's Avatar
I bet the optical eye is either out of line or broken. I am not sure if it can be fixed. Like you I am not a know it all on these things. I would hope someone can fix it but in todays throw away world it may be cheaper to replace it. One more thing to try, hit it with a hammer and see if it helps. [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
Old 11-12-2008, 08:53 AM   #9 (permalink)
Gumbeaux's Avatar
Mine just started doing this exact same thing. I get sound, but a scrambled picture.
How did you go about fixing this?
2004 Excursion 4X4 Limited - All options except 2nd row buckets - 6.0 PSD - X Springs front and 4" blocks in the rear - 295/75R16 BFG AT's - Superchips programmer - Ranch Hand brush guard - Sirius Radio - Infinty speakers, Blaupunkt powered sub - Garmin GPS - ProComp shocks - Thule rack My Photos
Gumbeaux is offline
» Sponsor Links
»Garage Storage and Cabinets
