Old 12-12-2004, 06:22 PM   #1 (permalink)
Rear end vibration
01 x with 43,000 miles. when turning from a stop i hear a vibration noise from the rear end. Took it in to dealer said they found no problem but the noise is getting worse. Where spline goes into rear end has started leaking. Any help on what the problem may be or has anyone had the same problem.
Chadw is offline
Old 12-12-2004, 08:32 PM   #2 (permalink)
Re: Rear end vibration
Differential's pinion bearing.
Hoowasat is offline
Old 12-12-2004, 08:37 PM   #3 (permalink)
If you have the limited slip it could be the clutches. Have them install 1 more bottle of friction modifier in the rear.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 12-12-2004, 09:23 PM   #4 (permalink)
How do i know if i have a LS rear end? It's a 01 limited 4x4. The vibration is worse while towing and turning. The truck also uses 2 quarts of oil between oil changes. I change it at 5000 miles.
Chadw is offline
Old 12-12-2004, 09:34 PM   #5 (permalink)
On the rear axle tag there will be a number like 3L73 this L stands for limited slip. There is also a axle code on the drivers door jamb tag that I can cross to tell. The only other way is to lift both rear wheels off the ground and turn one while watching the other. with the trans in neutral they should both turn the same direction if it is a limited slip. As far as oil usage that is normal for this engine and you will use more when towing.
Excursion Pics
Old 12-12-2004, 10:05 PM   #6 (permalink)
I will check this out tomorrow and let you know. Thanks
Chadw is offline
Old 12-12-2004, 11:41 PM   #7 (permalink)
Mine started doing that after a service to the rear end, so drained it and put in new synthetic oil with that friction modifier, and sounds fine now!
06 Mega Cab CTD
06 F150 KR
08 Polaris Ranger RZR
06 Buell Ulysses
00 XR650L
damodt is offline
» Sponsor Links
»Garage Storage and Cabinets
