Old 03-06-2006, 01:33 PM   #1 (permalink)
Rear Engine Oil Seal?
Dealer told me on Saturday, that 'a rear oil seal went out'. The previous day I had noticed oil drips on the driveway and figured my usual dealer didn't tighten the drain plug enough (again) because it had a lot of oil on/around it. But I was perplexed since the oil change had occurred 3 weeks previously (I have them do the changes as part of the pre-paid maintenance plan). The next day (after 80 mile commute) I noticed a lot more oil. Again, I crawled under the X and couldn't locate a leak (drain plug was secure), but noticed quite a bit more oil in locations that couldn't have come from the drain plug, like on the top & side of tranny housing and streaks that went back along the underside of the vehicle. The oil was dark, obviously engine oil.
Anyway, I decided I wanted to try a new dealer and there was one open on Saturday that advertised having a truck center. The service rep called and left a voicemail saying I had a leak at an oil seal. It is warranty.
BTW, I checked my oil level before driving, and it was down to the lowest 'ok' mark on dipstick.
Anyone else experience this at 66,000 miles? Seems premature to me.
2002 Excursion PSD Limited, 4X4, Aspen Green, Cortex Tuner, Walker BTM, A pillar gauges, Bilstein shocks, Ford finned diff cover, Hellwig Sway Bar, and BFG LT285/75R16E tires.
coldpizza is offline
Old 03-06-2006, 04:26 PM   #2 (permalink)
Re: Rear Engine Oil Seal?
Dealer called and said it was the rear main oil seal...
Seems odd as they fixed it already (1/2 day) and seems like that job would take longer. Anyway, between this, the front spring replacement, and two hydraulic power (steering/brakes), I'm starting to think the extended warranty may pay off after all (major services/repairs since 36k miles).
Len
Old 03-10-2006, 02:49 PM   #3 (permalink)
KGP
I just started noticing some oil spots on my driveway (77K miles). It's coming from the area that may also be a rear main seal. Guess I'll take it in. I would think the standard engine warranty would cover it should it be the rear seal?
KGP is offline
Old 03-10-2006, 10:31 PM   #4 (permalink)
my x has also started to leak at the rear main,it has 80k, i don't think i will fix it, probly have other trouble after the dealer fixes the leak, so leave well enough alone.
97 f350 cc 4x4, srw ,tde1, 4.10 gears,head studs w/ factory gaskets' bts tranny mobil 1 synthetic diesel site full pull injectors h2 turbo, 02 hpop ,twin tymar intake ,beddins custom fuel system ,custom ladder bars,turbo life saver,dead kitty, ,dp tuner 4 position chip,hypermax innercooler,oil filler extension,,maghytec pan,4inch exaust w/ 4" stacks, aux tranny filter,dual aux tranny coolers, autometer a-pillar 3gauge,295 nitto at's,4inch lift,ranchhand bumpers front&rear
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!!
scottginfla is offline
Old 03-14-2006, 06:48 PM   #5 (permalink)
MotionMan's Avatar
I'm with you, if they open this up to fix it there are way too many things they can screw up. If it gets supper bad I will do it and know it was done right.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 03-16-2006, 02:12 AM   #6 (permalink)
I'd bet a 100.00 bucks that it is NOT a rear main seal but the infamous turbo "o" rings. It leaks onto the manifold and down the left rear of the block where it mates to the tranny bellhousing and comes out of the weep hole in the inspection plate "appearing" to be a rear main seal...
Tom [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
CTFD
Contact Info.. tom@reynolds-excavation.com
512-762-1485
LATE 1999 F350 CC Dually 2WD,4" stainless Magnaflow.Highly Modified GT38 Turbo
DP-Tuner 4 Pos. chip, PS2000,4" intake with fleetguard filter ,Suncoast Tranny With Triple disc T/C, Lunar Guages
12 Speaker 770 watt Fosgate,Sony and Infinity system with (((XM))), Stull Billet,BFG's and acetoned badges.ART rotors, More to come. 8100lbs.
1/4 mile 14.80 @ 94.24 MPH
2000 Limited 4X4 Excursion Toreador red and tan,(((XM)))Rancho RSX's, Hellwig anti sway,V codes on front, skyjacker dual stabilizer, Edge Evolution AFE with PG7, Eddins House of Diesel 4" Exhaust with Polished 5" tip, Suncoast tranny with triple lock, 15.1" DVD monitor,now rolling Akuza Bounce 20's w/ Toyo 305/55/20 AT's
OUR TRUCKS and new ****350Z ****
EXCAV8TER is offline
Old 03-16-2006, 12:20 PM   #7 (permalink)
i had the same exact problem on mine about 2 years ago, mine ended up being a dirty air filter, causeing the engine to suck more crankcase fumes then normal,
it looked like it was leaking at rear main also
i now change my filter on a consistant basis
glenn z
1978 bronco XLT ranger, 4x4, hopefully soon to be an IDI candidate
1939 ford coupe, 351 cleveland supercharged, 33 x 19.5 mickeys out back, 700 + HP
2002 harley softail duece, many upgrades....
1972 ford torino, 351 Cleveland, AOD, in process
glennz is offline
Old 03-16-2006, 01:14 PM   #8 (permalink)
Scroll down to Denny's Diagnostics. This could be the cause, also.
http://www.asaaz.org/newsletters/road-sept04.htm
rexleone is offline
Old 03-17-2006, 02:19 AM   #9 (permalink)
While changing my oil a couple months ago I too noticed oil all over the back of the engine block and on the underside of the vehicle. After reading these forums for a couple years, I figured it just HAD to be something major, right? Disappointed that I was having problems at only 38k miles, I rush into my Ford Truck dealer. Well, two hours later it's fixed - it was only leaking turbo boots. They took the boots off, cleaned the oil out of the inside and reinstalled them.
I just gotta do that CCV mod......when the weather warms up!
2003 7.3 Excursion, Sylvania Silverstars, Fumoto Valve, Schaeffer 9000 oil, Ford AIS, Rancho RS9000X shocks - replaced with Bilsteins, Rancho steering stabilizer, Hellwig rear sway bar, Goodyear Wrangler Silent Armor tires, Mobil 1 *Mercon* ATF in transmission/transfer case, CCV mod - returned back to stock, more to come!
walt501 is offline
Old 03-17-2006, 12:36 PM   #10 (permalink)
Interesting. When I was under the X, I saw the hydraulic lines and thought it could be leaking from one of them (it was creating a large oil spot under the truck) but I couldn't see 'squirting' or the real source.
I wouldn't doubt that, that is actually what was fixed and the shop still kept 'replace rear oil seal' to match the diagnosis. It was a warranty fix so I didn't even question it.
The good news is, no more leak or drips, and I think it even runs better [img]/ubbthreads/images/graemlins/crazy.gif[/img] (sort of like how much better it runs after I've detailed it).
Thanks for all the input.
Len
» Sponsor Links
»Garage Storage and Cabinets
