Re: Rear hatch will not lock
Will the key turn or is it frozen?
Several years ago mine was frozen. Applied liberal amounts of liquid graphite and kept trying. After a couple of mins it worked and has been fine since.
The key hole attracts a lot of dirt so clean and apply graphite every couple of months.
If this does not work then new one required. Bit of a pain to change as limited access also ask dealer to key it for you no charge.
Dunc
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
