Rear parking assist sensor - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 06-24-2007, 07:40 PM   #1 (permalink)
My rear sensor quit working. When I put the truck in reverse the light on the sensor off switch comes on, stays on, until I hit it several times then it'll go off. No beeps at any time.
It used to work very well and I got used to it but don't want to pay several hundred dollars to get it fixed. Any ideas on what the problem could be?
dave
01 Excursion, Ltd. PSD, EBM2, 4x4,arrived 11/22/00. Adds:TRUCK VAULT,Automate Alarm,3 Autometer Carbon Fiber Gauges on A Pillar,TTM.
Tecate Virgin is offline
Old 06-25-2007, 05:57 AM   #2 (permalink)
BDS
Re: Rear parking assist sensor
Dave, I had a similar problem with mine...I had an extended warranty on mine so I sent it to the dealer to get looked at. I HATE the dealer but I figured I would use my warranty. They found one of the four sensors was bad. The two center sensors are different than the two outer ones. They have a scanner to check out the entire system to find the problem.
Good Luck,
Brent.
96' F350 XLT C/C PSD 4X4 LWB-Green...His, SOLD IT, Stupid Move, Found Another!
97' F350 XLT C/C PSD(for now) 4X4 LWB-White...His
01' Excursion PSD 4X4 Limited...Hers
Trucks
Sled Pull
BDS is offline
Old 07-12-2007, 02:25 AM   #3 (permalink)
My 01 has always worked flawlessly, but with my 03, as soon as I put it in reverse, it just makes the solid beap sound the entire time. Maybe I'll take it in for that check of the sensors. I'm off my warranty, did they say what the repairs would have cost?
Related issue: On the 03, I was going to replace the black rear bumper with a chrome one. Do I need to find an 03 bumper or are they all the same? I will say the beap tone on the 03 sounds different from the 01, the 03 seems to have two tones - one higher one lower - but maybe that's unrelated to the bumper itself.
'03 X Limited 4x2, V10, Black, Front Console replaced with SD Center Seat, tinted front windows, cladding removed, Monroe Reflex shocks, Helwig Antisway front & rear.
2big4burb is offline
