Has anyone had any trouble with the rear pinion seal leaking?
Mine just started leaking, noticed it last night.
Cray has the same X, built 2 months after mine and he has been thru two seals.
The service writer at the local dealership told him there are two different seals and he probably got the wrong one.
Anyone know anything about this??
any tips or tricks?
Thanks,
Jack
__________________ 2000 PSD Excursion Limited 4x4. Black/Gold. Jack-It 3-1/2 inch kit--315 Mickey Thompson MTX. APC headlight harness with 65/100watt bulbs. Nokia auto hands free kit with "left hand" mount.PSD front fender badges. In tank mod, pre-pump mod. Pro Liner roof. Home made tymar type intake with K & N cone filter RC-4780. Bullydog stock/45/75/125 chip, Over 202k miles and going strong.
Mine just started leaking at around 50k miles. Does anyone know if this is easy to replace myself? Cost?
You can fix it yourself, but I would say to let a pro do it. You have to get the pre-load right when you replace the pinion yoke nut, and (IMHO) that takes experience.
Yes mine leaked at 500 miles. Was slinging oil onto the tail pipe but would not drip. Dealer fixed it in no time (2 days along with rear main). No leak after the fix but now it howls durring deceleration at 40 to 50 mph. Dealer fixing it as we speak - says -replacing pinion bearing and will replace ring and pinion just to make sure they get it right (their a little red faced after returning my X from rear main repair with the tranny a quart low).
Jim
PowerTug
03 Excursion Limited PSD 4X4 3.73 LS
Build 3/20/03, C95 Injectors, Updated VGT, December 04 flash, Harpooned, Second Hot Water Shutoff Added for A/C, Updated DVD Entertainment Center wireless headphones, SiverStars, Fog Light Retro with 9005 SilverStars
Average MPG 17.5?, City MPG 16?, Highway MPG 19.5?, Towing Bass Boat MPG 17?
It can be done yourself but just the fact that you asked I'd advise you against it.
Cost for DIY is around $30.00 for seal and crush sleave if you got it right. $1,200 if you didn't.
