Old 09-30-2003, 05:03 PM   #1 (permalink)
Rear Pinion Seal Leaking - MagHytec
At 50k my rear differential pinon seal started leaking as have some of the other Ex's according to various posts. I installed the MagHytec cover at 30k and set the fluid level using the dipstick that comes as part of the new cover. The shop I had replace the seal mentioned that the fluid level was a little high which may have caused the seal to begin leaking prematurely but that typically in the 50-70k range they all begin to wear and leak. They said the best way to assure the proper level is to use the factory check plug on the side of the diff. If you have the MagHytec cover you may want to double check the fluid level using the factory check plug to get it set right. All is well now with the new seal.
NautiqueHauler - Black 2000 Excursion PSD 4x4, Helliwg Sway Bar (F&R), Billsteins, Husky mud guards and floor liners, Garmin GPS 2610, Bridgestone 285 A/T Revo's and a CPS in the glovebox!!!
Bill Tifft is offline
Old 09-30-2003, 05:12 PM   #2 (permalink)
Re: Rear Pinion Seal Leaking - MagHytec
Bill, did you watch them do the job?? Would like to know how they re-assembled?? I had mime done and it was done wrong the first time and only torqued to 165 ft/lb the second time. There has been a lot of discussion not too long ago about this and it is still fuzzy to me.
Thanks,
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 09-30-2003, 06:50 PM   #3 (permalink)
Paul,
No I did not watch them but I took it to a shop here in San Diego called Pro Gear. All they do is work on 4x4's gearing, transfer cases, differentials, etc. The shop foreman stepped me through the process of getting the proper crush ring and seal. Measuring the torque it took to get the old nut off and then re-tightening the new nut and crush ring to the exact spec that they took the old one off. There is an art to setting the pinion and pinion bearing pre-tension so that the ring and pinon gear set mesh properly and last for many miles without problems. Ford wanted twice the price and to have those guys work on it. Anytime a Ford tech touches my rig I get real nervous. This shop does work on these same seals 2-3 times a week on the Super Duty trucks. If they weren't doing it right they wouldn't be in business. I feel confident that I won't have any future problems.
-Bill-
Old 09-30-2003, 09:06 PM   #4 (permalink)
Your process is exactly how my personal mech. explained it to me. Trouble is that two Ford dealers have done mine and have not got it right yet. Even though I can get it done for free, under their 12k miles,12 month warranty, here at home I am still leery. I just might pay the local rear end only shop, I have used before, to reset it. As you indicated it is an art, experience, and knowledge to do it right.
Thanks for the response,
Paul B
2000 Honda CRV EX
PIC'S
Old 10-01-2003, 06:48 AM   #5 (permalink)
I just had mine done at about 48K by the Ford dealer (out of warranty). Seems to be holding up after a 2k miles. Did either of you notice a reduction in your gas milage when the fluid was low?
2001 Ex Limited 4X4 V10 3.73 LSD,Heated seats,Reverse sensing system, Rancho RS-9000's, Rancho RS-5406 steering stabilizer,Hellwig rear sway bar,and 6 disk changer.
orion7144 is offline
Old 10-01-2003, 05:27 PM   #6 (permalink)
My fluid was never low. This happened on vacation and I noticed black spots on the front of the TT when I stopped for fuel. Looked under and saw minor splattering on the wheels. When the mech. checked the fluid after re-installation it was right where it should be. I watched the entire operation. So all in all no change in fuel mileage. Average MPG on 6.5k trip from Florida to Grand Canyon and back was a solid 12 mph! I thought this was good, seeing temps were from 100* to 106* most of the time, 70 to 75 towing and solo. If I remember low was 10 and high was about 17 mph.
Sorry for the long reply,
Paul B
2000 Honda CRV EX
PIC'S
