Re: Rear Springs???
You are right, you will gain no height. What it will do is make it a greater distance until you bottom out on the bump stop if you hit a large enough bump because that year bump stop is not as thick. I cut the bump stops on my 2000 X to keep it from hitting them on every little bump. I am now starting to look for some V code springs for the front because my stockers are crap.
I also have a question for all of you?? I thought most people were upgrading their front springs to V code as in Victor or X codes which are the more heavy duty ones they put on for snow plows. The typing I am seeing is showing U codes as in Ugly...is this right??...or do you all mean V codes as in Victor?? Please advise for I am beginning to search for some new front springs from some local lift shops.
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
