Old 07-16-2008, 09:47 PM   #1 (permalink)
Supporting Member
detroitfd's Avatar
Rear squatting with trailer
Hey guys-
I have an Equal-I-Zer WDH hitch, but my Ex still squats just a bit. The ride is great (surprisingly) but it does sag a bit. I know I could use air bags, but that's a bit more than I'd like to spend at the moment.
I've seen posts on the spring mods...will this work to cure the sag? If so, could I get some pricing and info on it? Thanks, yet again!
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ serviceable S&B filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - Exhaust : 4" Turbo Back (w/ 4" down pipe) Stainless Steel Magnaflow - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - Dieselsite HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge face - Dual in-dash DVD
TOWING:
1996 30' KIT travel trailer - 7000lbs
detroitfd is offline
Old 07-17-2008, 08:39 AM   #2 (permalink)
I would do a B or F code SD rear spring change with the spring pack mod I came up with. It should help .. but how much?? Whats your tong weight and how much did it sag?
I never have used a Equal-I-Zer WDH hitch but I thought they could be adjusted to level the truck?
PM me if you want info on modding the springs, cheap easy to do.
Cary
95 f250 4x4 xlt Excab Lb. white, BTS Trans, 4.10ls, Dana 60, ORU RS kit DR 4"front 5" reas springs!, Bilsteins, Centerline 18x9", 37" Toyo MT's,H2e, Tapercore IC,3" Billet intakes, Tymar 4" exhaust,intake and HX mod,Beans 2's, Stealth and Fuel system and DI studs, JS's IDM mod, TW 4 pos chip,TSM Rear Disks, 198k miles. For sale from 100% stock to ??? PM for details
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 07-17-2008, 09:21 AM   #3 (permalink)
I have Timbrens on mine, they seem to do the job just fine with the W/D hitch. Cheaper than airbags and easier than springs.
FS
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
S.S. HX(removed for now)
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
Landyot's Radius Rods
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges
'99 E350 Snake Oil Wagon, 200+K, doesn't burn oil, lives on the bump stops & has a hard life. Runs like new.
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
fastersteve is offline
Old 07-17-2008, 03:04 PM   #4 (permalink)
I'll vote for the Tembren's....I've got them on my X, and they seem to work OK...
You might also consider some Bilstien shocks, and a sway bar for JC Whitney....plus some "E" rated tires.....
Then you got the whole package....
XS_SUV
Graupp is offline
Old 07-18-2008, 05:21 PM   #5 (permalink)
Supporting Member
detroitfd's Avatar
Cary
I don't know the exact tongue weight, and it probably sags about 21" more than the front. I am goin gto try and readjust the Equalizer to see if that helps, but I did it once before, and I don't think it'll do much. I'd love some info on the spring swaps. Thanks!
Jerry
My PSD X
TOWING:
Old 07-19-2008, 05:23 PM   #6 (permalink)
Jumping in here. Got a new (to me) 7.3 X PSD, '01, and will be towing 7500#. Will something like a Hellwig bar and Bilstein shocks give me enough stability in rear? Will I need Timbrens also?
ramblemutt is offline
Old 07-20-2008, 05:01 PM   #7 (permalink)
"""""Will I need Timbrens also?"""""
"""PROBABLY ???? """"".....I've got a 10K trailer, and it helped quite a bit....
So did the Bilstiens, and the sway bar ,and the E rated tires....
XS_SUV
Graupp is offline
Old 07-20-2008, 09:11 PM   #8 (permalink)
texaspsdx's Avatar
I swapped my rear springs to those from an F350 4x4 that I picked up at a 4x4 shop that had removed them from a new truck when they did a lift. Fit with no problem and helped the rear end of mine a bunch.
Ron
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout
Hensley Arrow No Sway Hitch
texaspsdx is offline
