Old 07-24-2001, 11:00 AM   #1 (permalink)
Rear Vent Power Window Stopped Working
All of a sudden one day, my passenger side rear power vent window stopped working. Nothing happens when I press the button to open it.
Luckily it did so while it was in the closed position. Looks like it's off to the dealer. [img]images/icons/mad.gif[/img]
Has anyone else had this problem?
Toolman
2001 4x4 Excursion-Limited, 7.3L Power Stroke, Chestnut, 3.73 Ltd Slip, TT Mirrors, Htd Seats, A/T Tires, VDO Gauges, Hypertech PPIII, Bilstein Shocks, Rancho Stabilizer, Hellwig Anti-Sway Bar, EPI Flex Pipe, K&N Air Filter, Husky Floor Liners, Fuel filler neck mod. Fog light switch mod., Optional (Dual Alt.) Upper Radiator Hose.
Toolman is offline
Old 07-24-2001, 11:57 AM   #2 (permalink)
Re: Rear Vent Power Window Stopped Working
your window is probably just stick to the seal. try the switch a coulpe times and it might begin to work again. If you get it open, slick down the seal with some silicone seal lubricant.
RECYCLED RACING TEAM - VHS 82BP
Conserve resources, recycle old racecars.
http://home.att.net/~rr-team/
Y2K X PCMs-AXDO/AXD1/MQJ0/????next
Recycled Racing is offline
Old 07-24-2001, 01:53 PM   #3 (permalink)
Location: Lumberton, Republic of Texas , Hardin County . and US of A
Toolman there has been a sticking problem a while back. Mine started making a squelling sound on the passangers side and they had to replace the motor assymbley. Been doing its thing ever since [img]images/icons/laugh.gif[/img]
Take care,
<font color="red">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~</font>
SMILES and the best to all**Ed-<font color="red">RETIRED</font>**OINKING-BILGE-RAT
<font color="red">FREEDOM IS NOT FREE ! ! !</font>
2005 LTD. X PSD 2WD FIBERGLASS RUNNINGBOARDS; SUNVISOR: REAR DEFLECTOR
<font color="00FF00">BENEFACTOR**<font color="red">NRA</font>**<font color="red">LIFER</font>**<font color="red">TX.ST.RIFLE ASSOC</font>**<font color="red">GOA</font>**<font color="00FF00">MEMBER</font>**<font color="00FF00">NRA/ILA</font>**<font color="red"> I VOTE ! DO YOU ? </font>**QUACK*QUACK ! ! !
<font color="00FF00">~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~</font>
H ED S is offline
Old 07-24-2001, 08:12 PM   #4 (permalink)
My X is at the dealer now having the motor assembly replaced on the same side.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Toolman:
Toolman
<HR></BLOCKQUOTE>
2005 6.0 PSD Excursion Limited Secert Service Edition (Black), 4X4.
curlysir is offline
Old 07-25-2001, 12:46 AM   #5 (permalink)
Yes I have had this problem! I was always able to "Unstick" the window and was able to get it working again. Then both windows started making a squeaking/grinding sound when opened and closed. It seemed to be worse when it was hot but did it no matter what. Last time I had it into the dealer I asked them to check and lubricate them as the squeak was annoying. I mentioned the fact that they had stuck ocasionally and the dealer them to check it. A few hours later the dealer called and said that they were going to replace BOTH motor assemblies and pivot arms under warranty. I think Ford has an issue with some of these units or why else would the dealer just decide to replace both of them. I seem to recall an earlier post that discussed this issue so I knew there might be a problem. So far no problems with the new units! You might see if there is a service bulletin on this problem. Good luck!
P.S. My PSD Ex. was built in Feb of 2000.
NautiqueHauler - Black 2000 Excursion PSD 4x4, Helliwg Sway Bar (F&R), Billsteins, Husky mud guards and floor liners, Garmin GPS 2610, Bridgestone 285 A/T Revo's and a CPS in the glovebox!!!
Bill Tifft is offline
Old 07-26-2001, 04:50 AM   #6 (permalink)
My Photos: (6)
I have this problem, periodically, with BOTH windows.
I don't they are stuck because when you click the switch you don't hear ANYTHING from the back, which leads me to believe it's either the switch or in the wiring...
2000 Excursion, LTD, PSD, Oxford White/Gold/Parchment, PPIII, Triple A-Pillar w/Autometer Gauges, 4 Exhaust, TT Mirrors, 6 CD, K&N, Bridgestone Revo A/Ts, C-Betr Mirrors <font color="red">(as endorsed by Porky Pig hisself!) </font>
Ford Excursion- Anything else is a lesSUV!
Hogballs is offline
Old 07-26-2001, 11:51 AM   #7 (permalink)
Yeah, mine aren't stuck. It's either the switch, wiring, the motor...or any combination thereof.
Toolman is offline
Old 07-26-2001, 01:07 PM   #8 (permalink)
My passenger side stopped working first, and then the drivers side died. Dealer replaced both motor assemblies. The motors both sounded like they needed lubrication before they failed. Fiddling with them would bring them back to life, but I left them dead so the dealer could "confirm the concern". The new ones are quiet, at least for now. If I have trouble again, I'm taking them apart.
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
shamuex2000 is offline
Old 07-31-2001, 11:40 AM   #9 (permalink)
My wife's passenger side isn't working. Replacement parts are on order.
2000 Ford Excursion Limited 4x4 PSD 3.73 ls
Hypertech PPIII, Weathertech floor and cargo mats
kbeaubs is offline
