Old 06-03-2004, 10:57 PM   #1 (permalink)
rear vent window motor, how to replace?
passenger side finally quit, milage is 44k so can't do under warranty, the motor is only 36.00 at ford so does anyone know how to replace these things? i haven't looked at it yet but i thought i would ask here and maybee save me some trouble, and possibly other broken parts.
97 f350 cc 4x4, srw ,tde1, 4.10 gears,head studs w/ factory gaskets' bts tranny mobil 1 synthetic diesel site full pull injectors h2 turbo, 02 hpop ,twin tymar intake ,beddins custom fuel system ,custom ladder bars,turbo life saver,dead kitty, ,dp tuner 4 position chip,hypermax innercooler,oil filler extension,,maghytec pan,4inch exaust w/ 4" stacks, aux tranny filter,dual aux tranny coolers, autometer a-pillar 3gauge,295 nitto at's,4inch lift,ranchhand bumpers front&rear
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!!
scottginfla is offline
Old 06-04-2004, 01:38 AM   #2 (permalink)
Re: rear vent window motor, how to replace?
Can't help with the install but am also curious. Mine act up a lot also.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 06-04-2004, 07:27 AM   #3 (permalink)
Very simple. The rear post trim simply clips on and off. I removed mine when I had that motor replaced under warranty (I didn't want to give the service guys any excuse to leave greasy hand prints all over my trim!) and again when I installed my beeper bypass switch. Just tug on it and the clips will pop loose. When you're done just line it up and pop it back in. You may need to pop off the connecting trim piece that covers the rear of headliner (I can't recall.) If so it's no big deal. It just pops in and out like the other panel.
'02 Excursion Limited 4X4 PSD- Helwig Rear Sway Bar, Bridgestone Dueler A/T Revos, Rancho 9000s, V-Codes, '03 Stops, F-350 Rear Blocks, Drilled and Slotted Rotors W/ Ceramic Pads, 4X2 Hatch Struts, Rear Air Deflector, AFE Intake,203* T-Stat and Billet Housing, HD-ELC (GO RED), Ford AIC, Jotto Desk , Sylvania Silverstars, '03 Badges, Wipers - 24" Front 17" Rear, Auxiliary Back-Up Lights, Reverse Sensor Alarm Override Switch
Dentman is offline
Old 06-04-2004, 10:54 AM   #4 (permalink)
At one point I had thought my vent window motor had gone out. I think they have some sort of “sensor” in them that turns them off when the hit a certain resistance. What happens with mine on hot days is that is gets “stuck” to the rubber seal. When the day cools off, and usually after it has been opened, it works fine. At least I think that is what’s going on. I know that the rear window door requires quite a tug to get open sometimes as a result of “sticking” to the rubber.
2000 Excursion. Pillar Mount Isspro Gauges, Stull Grill, Bilstien Shocks, SuperChips Programmer, PSD Badges.
Hookster is offline
Old 06-04-2004, 11:13 AM   #5 (permalink)
Dentman, do you have any pictures of how you did your beeper bypass?
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 06-04-2004, 02:04 PM   #6 (permalink)
MotionMan's Avatar
I find that like an emergency brake if you don't use it it will break. I had mine act up but I use it all the time now and it is getting better, it used to make noise. I am glad they are easy to fix so as long as it does not get stuck open I should be fine [img]/ubbthreads/images/graemlins/smile.gif[/img]
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 06-04-2004, 05:37 PM   #7 (permalink)
thanks guys, easy fix , took about 10 minutes to do.
Old 06-04-2004, 06:47 PM   #8 (permalink)
Sorry Dave,
No pics. Really simple though. I just spliced a Wal-Mart rocker switch into the red wire to the beep-beep-beeper. The most difficult part for me was getting up my nerver to cut the hole in the trim panel for the switch which I mounted a few inches below the speaker.
Dentman is offline
Old 06-05-2004, 08:49 PM   #9 (permalink)
Thanks! I need to do that next time I'm working back there. I'd really like to disable that bugger when a trailer's on.
Regards,
Dave
2003 Kubota B2910
dmftoy1 is offline
» Sponsor Links
»Garage Storage and Cabinets
