Anyone else having a problem with their rear washer leaking fluid down the back of the doors when not in use? Never use the rear washer, yet I have a small trail running down the door. How can I cap, or plug the line?
It is on the outside as if it is slowly flowing from the tip. It probably is no more than 10-15ml a week, but just enough to leave an ugly stain down the black "clean" door.
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Enough to put the tank higher than the back nozzle?
That is about the only way I can see it happening.
Just my thoughts
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Nope, truck is either parked in the garage or parking deck at wifeys office. I'm going to tear into it this weekend, worse case I'll just plug it off seeing as how I never use it. Just bugs me having a clean truck with a water mark down the back all the time.
If you are just lucky enough to have one that is all sealed up heating during the day could do this
Try leaving the cap off for a day or two and see what happens
Just a straw grasping thought but give it a shot [img]/ubbthreads/images/graemlins/smile.gif[/img]
bruce
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Close to empty could be worse
Air expands a lot more than liquid on temp rise.
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Well guys whenever Murphy can kick in he does [img]/ubbthreads/images/graemlins/blush.gif[/img] Want the washer to leak, it won't. Been watching it for over three weeks and nothing. Thinking like suggested might be a reaction to heat during the coarse of the day causing expansion.
