Old 12-19-2004, 11:44 AM   #1 (permalink)
rebuild of fuel filter bowl, water drain lever ???
well after 5 years of trouble free opertion i have my first problem,
my 2000 XLT 7.3 is stored in doors and keep warm so ice should not be an issue,
here is the story
yesterday ( saturday ) did and oil change and fuel filter and air filter change on my X
everything went well as usualy, and turned the lever on the fuel filter bowl to drain any contamination or water out of bottom of bowl...turned the lever back to the closed position and has not stop leaking since...
it is not a big leak just a constant drip, more so with running ( fuel pressure ) and slight drip while not running till it empties the fuel bowl
has anyone had to rebuld the lever unit yet, i would assume just an O-ring in there just not sure how comes apart or do i need to purchase a complete fuel filter housing
glenn z
1978 bronco XLT ranger, 4x4, hopefully soon to be an IDI candidate
1939 ford coupe, 351 cleveland supercharged, 33 x 19.5 mickeys out back, 700 + HP
2002 harley softail duece, many upgrades....
1972 ford torino, 351 Cleveland, AOD, in process
glennz is offline
Old 12-19-2004, 12:22 PM   #2 (permalink)
CHPMustang's Avatar
Re: rebuild of fuel filter bowl, water drain lever ???
O-Ring Kit from Blackcloud Diesel,scroll to the bottom of the page [img]/ubbthreads/images/graemlins/cool.gif[/img]
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 12-20-2004, 08:43 AM   #3 (permalink)
well got lucky, being i am super cheap. i figured i would pull the valve off and see if i could find rings locally.
pulled off and turned o-rings over and no leaks...
you could see where rings were worn by the check valve on one side
glenn z
glennz is offline
Old 12-20-2004, 12:05 PM   #4 (permalink)
CHPMustang's Avatar
Okay way cool,leak problem resolved [img]/ubbthreads/images/graemlins/smile.gif[/img]
Some of the guys go to Home Depot and get the O-rings but not sure if they are Diesel compatible [img]/ubbthreads/images/graemlins/wink.gif[/img]
Bill
Old 12-20-2004, 03:01 PM   #5 (permalink)
That's good news. If they're at all like the o-rings in my faucets that will only fix it temporarily. (it's how I fix a dripping faucet). Seems like I get 3-6 months out of them when I do that and then I have to put in new one's.
Just my .02
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 12-20-2004, 07:56 PM   #6 (permalink)
well the big difference between a faucet and this is that the bowl drain lever gets used very little and faucet is used daily...
i am hoping it lasts for while, lasted 5 yrs so far,
glenn z
glennz is offline
Old 12-20-2004, 08:18 PM   #7 (permalink)
That is true. I only open/close mine once a month.
Have a good one,
Dave
2003 Kubota B2910
dmftoy1 is offline
Old 12-20-2004, 09:04 PM   #8 (permalink)
CHPMustang's Avatar
Maybe I should check em once a month myself instead of once every 6 months when the oil change is done.
Old 12-21-2004, 08:07 AM   #9 (permalink)
I don't know if it's a good idea or bad one, but I saw that they were doing it on the Turtle Expedition trucks so I figured it couldn't hurt. I just do it as part of my monthly check of air pressure, etc.
Have a good one,
Dave
2003 Kubota B2910
dmftoy1 is offline
Old 12-21-2004, 09:24 AM   #10 (permalink)
CHPMustang's Avatar
I have not had the assembly apart to check that valve to see if it can be lubricated with silicone of something alike without disassembling,what do you think?
Old 12-21-2004, 07:11 PM   #11 (permalink)
mine didn't looked lubed, but the o rings were painted yellow, not sure what the idea was on that, some of the paint actually flaking off of the o-rings, thought maybe that may have caused the problem,
2 days now, no leaks still diesel smell,
to cold here to wash truck underside and engine, wait a few weeks till warms up...
glennz is offline
Old 12-22-2004, 07:12 AM   #12 (permalink)
You'd think they'd be "self-lubing" with diesel fuel up against them wouldn't you?
I've got no clue. I'm probably going to order one of those rebuild kits though and stash it in the same place as the CPS and spare fuel filters! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Have a good one,
Dave
2003 Kubota B2910
dmftoy1 is offline
Old 12-22-2004, 10:58 AM   #13 (permalink)
CHPMustang's Avatar
From the sounds of it the O-rings are partially exposed to open air and if you're in the southwest it's dry so i can see the lifespan of them alot shorter.
I may have to give them a looksee if I can get any WD40,silicone spray or somethin in there.
At least one of the sponsors has the rebuild kit for us [img]/ubbthreads/images/graemlins/cool.gif[/img]
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and
