I stopped at a gas station and some idiot tried to break into my X. As the result I have a gap around the door handle and the door. I need to remove the inside door panel to pound out the kink and make the door handle fit flush. Any suggestion or warning? TIA.
1. behind the lower light on the inside door panel behind the lense is a screw, remove it.
2. pull up on the electric window oberator and it will snap up. in that area is another screw, remove it. Also unplug the window controls. I believe at this point the panel will lift strainht up.
01 PSD Excursion XLT 4x4 Wedgewood blue,Born on 3/21/01,Delivered 9/01/01, Troy console w/GPS&Cb radio, catch-all floor mats,clear corner lenses,dynomax race bullet muffler,x springs & 4"rear blocks, Bilstein 5100 series on all 4 corners. BFG AT 33x12.5x16.5 on Eagle 589 16.5x9.75, XM Radio
Hey AZ, did that happen intownor were you on the road???
Rich in Chandler
1993 Freightliner FL 70 GVWR 25,640lbs. crew cab c8.3 cummins alison 3060p 6speed auto with hauler bed "Now were serious about towing a heavy load".
2005 F350 4x4 C/C LB Dually Lariat TowBoss--sold
2004.5 dodge CTD- no tow & had to go
2005 KZ 43ft New Vision Toy Hauler 3 slides & 14' of enclosed garage
2007 Mercedes Benz GL 450
1956 Willys DJ 2 Wheel Drive(long term project)
1951 Willys M38 (on going project)
[url=http://www.flickr.com/photos/xploringaz/sets//[/url]
