replacement sway bar end link bushings ? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 12-06-2009, 08:48 AM   #1 (permalink)
njneer1's Avatar
Can't find any place that lists the replacement bushing kits for the 4x4 Excursion. For the F250/350 you just press the old ones out and replace with the energy susp kit....will these F250/350 ones work on an EX ? same size etc? or are they different ?
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
njneer1 is offline
Old 12-06-2009, 11:18 AM   #2 (permalink)
njneer1's Avatar
Everyone with an Excursion has had to buy the whole link assembly ??? All the tread searches turned up nothing.....maybe when the west coast guys wake up I can get some help.
njneer1 is offline
Old 12-06-2009, 04:59 PM   #3 (permalink)
Hi
Check this post:
ES sway bar bushings..
Good luck
Excursion 2004 4X4 Limited - PUEBLO GOLD - 6.0L T-C Diesel - 5-Spd Auto Trans -AM/FM Sterio In-Dash 6-CD - Rear Seat Entertainment - DVD - 2nd Row -Dual Bucket Seats - PWR HTD T-T Mirrors - 3.73LS Axle - T-Case Skid Plate - Thule Top Rack - SC Tuner
Veh. Built 7/16/03 Eng. Build date 6/27/03 by International - Purchase Date 9/1/03 Milage on date 6/9/04 = 15,000 11/15/04 = 26,890 4/19/05 = 35,639 12/12/05 = 49,810 8/29/06 = 63,750 3/27/08= 100,003 Rancho 9000 shocks F & R.
It is hard to take travel serious when every time you leave home you take an Excursion !
Mesu
mesu is offline
Old 12-06-2009, 07:37 PM   #4 (permalink)
njneer1's Avatar
Originally Posted by mesu View Post
Hi
Check this post:
Good luck
Thanks, Now that makes sense......I knew the sway was larger !
njneer1 is offline
Old 12-06-2009, 08:43 PM   #5 (permalink)
i pressed energy ones in mine and pops 2wd.dont remember part numbers though.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
