Re: Replacing headlight cover
too bad you now have to buy a new cover, but on the bright side you get to buy the 2002 assembly. its not too bad to change them out first you remove the two top clips by pulling them up, the best way is to stick a good black wire tie thru them and left up with your klien's, its the bottom one that is a bit of a bugger, I used a 14 mm 12 point socket to slid over it and press in thoise little finger then just pull the whole assembly out.
mike
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
