Old 10-17-2005, 07:30 PM   #1 (permalink)
Resetting Lock keypad on the door
My father in law just bought a 2000 x but the dealer didn't have the code to unlock the doors on the door keypad. Is there an easy way to reset this code?
93 F250 IDI 4x4 Supercab Longbed Rebuilt E40D AT; 4.10 gears; Magnaflow high flow muffler, 3" pipe and 5" stainless tip! 285/75 Liberators on stock rims; cut soup bowl. 168,000 miles and counting! MORE TO FOLLOW!
redneckdiesel is offline
Old 10-17-2005, 08:06 PM   #2 (permalink)
FJF
FJF's Avatar
Re: Resetting Lock keypad on the door
If you bought it from Ford they can retrive the keyless# buy hooking it up to there computer and pull up that info. I never found a sticker with the numbers on it anywhere. Ford will put the # on a sticker and place it in out of the way spot.And you cannot reset without the old code [img]/ubbthreads/images/graemlins/mad.gif[/img].FJF
2000 Excursion Limited 4X4, 5" Hypermax Exhaust,TS 4 Bank chip(D/P Tuner- stock,Tow,Econo,Race) A Pillar DiPricol Gauges (white face)Hellwig swaybar,Skyjacker stablizer,AFe Stage2, Slotted&cross drilled rotors,BB Turbo,Pioneer AVIC D2 <font color="RED"> *** ALL GAVE SOME, SOME GAVE ALL(FDNY 9/11/01)***
FJF is offline
Old 10-17-2005, 08:14 PM   #3 (permalink)
MotionMan's Avatar
My factory number is on a card in the owners manual pouch. It is true that with the truck and the VIN they will let you have it, you need the truck there or they will not let it out. Then the manual tells how to change it, if you don't have a manual I could fax the page to you, it is easy. Good luck.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 10-17-2005, 11:51 PM   #4 (permalink)
Yep, in addition to the card in the packet, I found stickers with the code on them under the hood, in the glovebox and under the rear hatch. I removed them when I found them for obvious reasons...
BayAreaBoater is offline
Old 10-18-2005, 12:38 PM   #5 (permalink)
thanks for all the input. One other thing, it only came with one key fob and one of the "chipped" keys. is there a way I can get around going to the dealer for those? Can the average guy reprogram a set if i was able to buy them on ebay?
Old 10-18-2005, 03:35 PM   #6 (permalink)
NOPE, you need two good keys. And only the dealer can give you the original number. From there you can do your own.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 10-18-2005, 05:52 PM   #7 (permalink)
Fobs are easy as EBAY not sure what the "TUNE IN PROCEEDURE IS" but it is fairly simple I have done it on other fords.
Keys you need two Except there was a post here a while back about how to do it with just one I THINK?????????? but not sure ???
Anyone else less foggy on this one
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-19-2005, 11:03 AM   #8 (permalink)
I too only received 1 key with my X. I bought 2 more on ebay, and then took them to a locksmith and he programmed them for $20 total. So call around, because they have to have a programmer, but the first one I called had it. I'm sure this had to be cheaper than the dealership would have charged.
BTW, using the ebay keys and no problems what so ever.
2003 Excursion EB 4x4, 7.3PSD, Rancho 9000's
X_man is offline
Old 10-19-2005, 06:10 PM   #9 (permalink)
I did the same thing as well. but I took mine to the dealer and it cost me $80 to have them program the 2 new keys. I pulled the key fob off of a wrecked ford in a junkyard. I only did it because I got it for free. I am going to be putting an alarm on it, so it will have keyfobs with it.
anyone know how to tie a Viper car alarm into the keypad, now that would be trick.
k5chevyblazer is offline
Old 10-21-2005, 01:17 PM   #10 (permalink)
I did not have the keycode to mine when I picked it up from the dealer, but I did find where it was on a 2005.
Remove the two screws that hold the "trash bag hook" panel and remove the panel. lay on the floor with a flashlight and look up and in the hole. Behind the radio is a box with a sticker on it. Lots of printing, but there is a set of rather large numbers on the sticker without any other notation or printing around it. 5 digits. That is the permanent keycode.
type this keycode into your touchpad on the door, and it will unlock. Within 10 seonds of the door unlocking, start putting in your new 5 digit keycode.
The new user keycode is programmed. The permanent keycode still and always will work.
2005 EXCURSION!! XLT V10 Silver Purchased 10/8/05 19920 Miles.
Heated tow mirrors, Hood/window deflector,Ford rubber mats, Firestone bags/air source kit, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Curt front reciever, 6 disk Visteon stereo, 6 disk changer in console, X-3 AIC, door lights,OEM Fog mod, volt/tran temp gauges,skid plate.
housedad is offline
Old 10-21-2005, 01:53 PM   #11 (permalink)
FamilyRide's Avatar
You could also say "start putting in an additional 5 digit keycode", since as you stated, the original/master will always be the master and can't be changed or deleted.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 10-21-2005, 01:57 PM   #12 (permalink)
Semantics.
But you are right. That is clearer.
housedad is offline
Old 10-21-2005, 01:58 PM   #13 (permalink)
FamilyRide's Avatar
Semantics.
I know, I know. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 10-24-2005, 12:45 PM   #14 (permalink)
A little off subject, but along the same lines. Is the keypad a 'wireless' device? What I really want to know is how does it get it's power? Internal Battery? or from the Vehicle Battery? Don't want an internal battery to fail me.
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline
Old 10-24-2005, 01:05 PM   #15 (permalink)
The door keypad is a direct wired unit to the vehicle computer. All power comes from the vehicle. They will work even when the battery power is too low to start the car, but if the car battery is dead, so is the computer and the keypad.
housedad is offline
