Reverse system buzzer location? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-10-2009, 07:47 PM   #1 (permalink)
Anybody know where the buzzer/alarm is located for the reverse system audible alarm?
I bought one and need to know where to look for it so I can change it. Thank you
I have an 2001 Excursion 4x$ PSD.
MARCSPSD is offline
Old 11-10-2009, 08:03 PM   #2 (permalink)
IIRC, right rear pillar. u have to remove all right side trim to get to it.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 11-11-2009, 06:58 AM   #3 (permalink)
Thanks Txangler. Just to make sure, do you mean the last rear pillar near the lift gate?
And do you know how to remove the trim without breaking anything? Any tips?
Thanks again.
MARCSPSD is offline
Old 11-11-2009, 01:39 PM   #4 (permalink)
If you look at the pass. rear pillar you will see the holes drilled in a circle. Remove upper trim strip (center)Pulls out on snap strips. Remove pillar (snap strip) Just go easy on the pulling so not to break plastic. A little at a time
c.salt is offline
Old 11-11-2009, 02:50 PM   #5 (permalink)
Thank you C.SALT
MARCSPSD is offline
Old 11-11-2009, 08:38 PM   #6 (permalink)
marc like salt said take your time i removed mine in 02. If i were you I would replace the speaker and clean, grease the window motor while you have it off. Do the left side if u are bored while at it!!! The rt side is harder than the left oh and I broke 1 tab on the rt side.
TXANGLER is offline
