Yeah, the diesel makes noise, the A/C fighting the 100 degree weather is loud, but wanted to stop the road noise coming in around the door....
Saw SOMEWHERE someone suggested taking vinyl tubing and inserting it in the weather stripping around the doors...
10 minutes per door and it was DONE !!!
And it stopped it completely...
My only caveat is they suggested 3/8" tubing and it made my door closing a LITTLE too tight...
migt try 1/4" to start and see if that solves it first...
REAL easy to do...
home depot has the tubing...
get 20 foot lengths or MORE... took about 15 to 18 foot per door...
on the inside of the weather stripping are "weep holes"
I snipped one of them a little larger, squirted some soap and water mix down there
inserted one end and started pushing...
took a bit of squirts into other weep holes as it got around the 3 corners, but eventually stopped...
cut that off, went to the part where stopped and started another length !!!
Worked great !!!
(maybe one day I will do HER side - for now - mines quiet !!! [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img]
kudos to whomever's idea this was !!!
DOH!! Now that sounds cool! I may have to try that.
In just learned about the rear door disconnect trick and it's sooooo much nicer loading things up, especialy with the boat behind it.
Now to find a way to stop the tow mirror from whistling when pulled all the way out! [img]/ubbthreads/images/graemlins/blush.gif[/img]
Larry, keeper of the <font color="red"> New revised </font><font color="blue">"little secrets" </font> CLICK HERE [img]/ubbthreads/images/graemlins/smile.gif[/img]
__________________ <font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
How about the backup beeper? What a pain when I'm backing a trailer into a nasty spot or hooking up.
There is a way for the dealer to program the computer so that once you hit the button once, the sensor stays off for the entire key cycle. Check the archives in the "General" forum.
I know some members were going to install a switch or install a relay so once you hook up a trailer, the reverse sensor stays off.
It is on my list, but have not done it as of yet.
Hope this helps,
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
Way at the bottom...
my 03 X had a split in the weatherstripping...
if not, roll the weatherstripping out anywhere and look within the "fold"
you will see little "weep" holes (for lack of a better term)...
I used knippers to open one up a bit more and was able to slip the tubing in there...
first I lubed it with soapy water...
maybe a cap might be a good thing on the end to allow an easier push ?
Any idea how to keep the doors from autolocking the second you move the vehicle?
Yes it is done via the keypad, don't remember how but it IS in the owneres manual. Only done it three times 95TC 02X 05X so I dont remember exaclty.
I think you put in the FACTORY CODE then hold a particular button for 5 seconds for somthing like that, did the 05 while waiting for the wife at the store. And yes it is reversable if desired.
If there is a way to do this I wold sure like to know it!
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Yes it is done via the keypad, don't remember how but it IS in the owner's manual. Only done it three times 95TC 02X 05X so I dont remember exactly.
Bruce
Bruce,
This is what I dug out of my X files for things to do next time I am at the dealer.
Special Service Message # 17815 - MULTIPLE VEHICLES -- PROCEDURE TO DISABLE REVERSE SENSING SYSTEM (RSS) FOR ENTIRE IGNITION CYCLE - SERVICE TIP.
To program the reverse sensing system (RSS) switch so it will disable the RSS system for the entire ignition cycle, rather than turning back on each time the transmission is put into reverse, Perform the following using the NGS service card (Green Card) Level 10 or higher
1 Select service bay functions
2 select PAM module
3 Select module option content (Hit Trigger)
4 Select Vehicle (Hit Trigger)
5 Hit trigger to highlight IGN or REV
6 Scroll to toggle between IGN or REV (Hit Trigger)
7 Select done which is soft key #8 (Programming Should Now Be Complete)
Effective Date 05/20/04
Dont know who originally posted it, and not sure what years it applies to. HTH.
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
Need to take my new one in as the trans is not just right, and a few other little things. I can have them do it then while they have it "hooked up"
Bruce
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
