Roof Rack Options... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 05-19-2009, 11:37 PM   #1 (permalink)
TXMoose's Avatar
Can those of you who have added roof racks post a bit about brand and models please?
All I have is the factory channels...Id like to start with just some feet and bars to perhaps strap fishing rod holders to for travel and eventually maybe a basket type attachement for gear and coolers etc.
There seem to be so many options so I figured those that have successfully implemented some would be the best to ask.
Any info/guidance is greatly appreciated...
Be well...
Robb
'01 PSD CC Shorty Lariat 7.3 True Blue 4x4
Ranch Hand Front and Rear/ N-Fab Triple Step Nerfs/ Rhino Liner,Hella Rallye 4000s on top Hella 550 fogs on bottom, Baldwin Coolant Filter/Auto-Meter Guages/ 203 deg T-Stat /Diesel Innovations tank/pre-pump mods/ Harpooned Tank/Mag-Hytec Tranny Pan w/ Mobil-1 Synthetic,Trans-go Shift Kit,AIH delete/Ford AIS Intake/ MBRP T304SS 4" Duals with 5" dual walled tips, Tuff Country 2.5 lift and BFG AT KO 315/70/17'sw/ Extreme Alloys/Rancho RSX9000 Shocks...127K mi More mods to come....
DYNO'd 10/30/04 HP-301.6 TQ-555.5
'01 Excursion 7.3 4X4- Sage Green
Edge EVO on DP Tuner 80 Econo / Coolant Filter/Ford AIS Intake
1-ton Springs rear and U Codes in front w/TuffCntry 2.5" spring pack / Rancho RS9000XL shocksFabtech adjustable Trac Bar /Ranch Hand Guard / BFG AT KO 285/75/16's / 195K and running strong.
TXMoose is offline
Old 05-20-2009, 09:18 PM   #2 (permalink)
Dunbar's Avatar
I already had a Yakima system for my Land Cruiser so I bought the feet to fit in the Ex factory rails. There are expedition type racks available but I use a utility trailer for the luggage which is much easier than throwing it on the roof.
Dunbar
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, Tymar DIY, Vcode & modified Fcode, Helwig, Inappropriately valved Bilsteins, Isspro 3 gauge w/ windshield mount, DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler,
BTS Transmission, DI Up pipes
Tomball Texas
Dunbar is offline
Old 05-24-2009, 12:28 AM   #3 (permalink)
i have had the yakima system which uses the factory rail for 9 years . it has a quick release with a keyed lock.i have had at least 250 lbs and driven hundreds of miles with it loaded.i have the biggest basket they sold,could be bigger but has worked great.no problems,still very pleased
j dooling is offline
Old 05-25-2009, 12:07 PM   #4 (permalink)
TXMoose's Avatar
any particular yakima part numbers or is there basically only one that will fit in there?
Thanks....
TXMoose is offline
