Old 12-11-2000, 06:43 PM   #1 (permalink)
Rooftop running lights
I looking to buy some roof top running lights for my Xcar. My wife said she MIGHT buy them for me if they didn't cost to much.........So what I would like to know is where can I get a price on them and are they a big problem to install??? Thanks..
Excursion 2000, 4X4,PSD,Estate green, 3.73, Skid plates, 6 CD,IAS shocks, etc.
curtjones is offline
Old 12-11-2000, 10:22 PM   #2 (permalink)
Re: Rooftop running lights
Just put a set on two nights ago. I got them from my buddies auto parts store. They were $40 bucks for the set of 5. It is a fairly easy install. Just unbolt the visors, overhead console, oh-**** handles and pull off the pillars. This will allow you room to wire under the headliner. You can run the wire down the pillar and right to the fuse box under the steering column. I choose to wire the lights into the parking lights and not run it off the headlight switch. I used the Chevy style lights as they look much better than the Ford lights. I also evenly spaced them across the top unlike Ford with three in the middle and two on the outside. Sure makes the truck look better.
Huck
01' Excursion PSD Limited 4x4, Oxford White, 3.73 Limited Slip, Heated Seats, In Dash 6 CD Changer, Bug Shield, K&N, 305/70/16, Pro Comp Stabilizer, Edelbrocks, Standard Knock & Cackle
05' F250 CC, SB, 4x4 Harley, Blue, 4 Buckets
00' F350 CC 4x4 Lariat Dually, BTS Trans, TS Chip
00' 40' American Tradition Motorhome 8.3L Cummins, Allison Auto., 2 Slides
02'Excursion PSD LTD, 4x4, Hypermax Stage 1+ Injectors, Hypermax H2E, Hypermax Tapercore, Hypermax 5", Suncoast, Air Raid, TS Chip, Pioneer DVD & Nav., XM, XTANT Amps & Subs in Rear Doors, Boston Seperates, PS2, 2 6" Drop Down Screens, Hellwig Sway Bar, Carbon Fiber Ultra Lite Gauges, 3" DR lift, 295/75/16 Nittos, Bilsteins & Steering Stab., (Burned To the Ground)
01' Excursion PSD Ltd. 4x4, Oxford White,3.73 LS, Heated Seats, In Dash 6 CD, ADS/U.S. Amps, JL Audio Seperates & Subs, Remote Start, K&N, 305/70/16 GY's, Pro Comp Stab., Edelbrocks, TS Extreme Chip, Sonnax Valve, Tricumulator Springs, Hypermax Combo Gauge, 4" Exhaust, EBM2, V Code Springs, 03' Expedition Console (Sold)
88' Porsche 930 Turbo Cabriolet 450 HP
76' Cadillac Eldorado Convertible
77' Jeep CJ-5 Covertte 350, TH 400,
Huckster is offline
Old 12-12-2000, 07:25 AM   #3 (permalink)
Huckster..
Thanks for the info..
Curt
Old 12-12-2000, 07:50 AM   #4 (permalink)
Do a search on "running lights" on the entire forum. There is a bit of discussion on it. Best I can tell is that you can order them from the dealer and there is a wire harness hook up down on the passenger side that the light warness will plug into. This is something that I to am contemplating on doing. Should look good, but I would keep the grouping of the three lights in the center, that's how all the big rigs have them.....> Eric
EWhite is offline
Old 12-12-2000, 11:17 PM   #5 (permalink)
If you end up over 80 inches wide (maybe some big fender flares?), you would legally have to follow the law:
The three center id lights at the high point of the leading edge of the roof, should be between 6 inches and 12 inches from each other. The two clearance lights should be as close to the outside edge as practical, but no more than 8 inches from the outside edge.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16D AT, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
ExcursionPSD is offline
Old 12-13-2000, 07:39 AM   #6 (permalink)
Thanx for all the help.. The Ford people are installing them next week. About $250 and I won't have to drill the screw holes and end up with a leaky roof. They are going to install them with a daytime running light switch so they'll be on all the time.
Old 12-13-2000, 10:35 AM   #7 (permalink)
curtjones or anyone else that my know-
Without starting a major argument about daytime running lights, I have a question. I would like to install daytime running lights on my Excursion. Does anyone know how the Excursions built for Canada accomplish this? Is it as simple as adding a module? Any suggestions would be helpful.
Thanks,
John
00 Excursion LTD PSD 4X4 Dark Satin Green/Medium Parchment Born 7/00 All Factory Options except Tranfer Plate Skid Plate
Goodies Added As of 11/10/00: Work/Back-up Lights Mounted on Hitch, Back-up Alarm, F+R "FORD" License Plate Brackets, "FORD" Tow Hitch Plug, Cargo Area Mat
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 12-13-2000, 11:33 AM   #8 (permalink)
JADFPE
My Ford Dealer says thats all that has to be done, add a relay, which they are going to do so my roof top running lights will be on all the time..
Old 12-13-2000, 02:31 PM   #9 (permalink)
POS
Huckster,
The Chevy lights fit snug? What about wiring harness - did you use a Ford one or just custom wire it?
<font color="red"> WIX filters at </font><font color="blue">www.fleetfilter.com</font>
POS is offline
Old 12-15-2000, 09:59 AM   #10 (permalink)
curtjones-Thanks
When you get the work done, please see if the dealer listed the part number for the relay. I would like to add the day time running lights to my Excursion.
JADFPE is offline
Old 12-15-2000, 07:15 PM   #11 (permalink)
Here ya go people Chris did a full install with pics on his cc here is the link
http://albums.photopoint.com/j/Album...871&a=10216719
05 F350 CC LB 4X4 DRW Lariat 6.0 Torqshift, Black Clearcoat, tow command system, upfitter switches, and almost every option except sunroof HERE
Dvheyden is offline
Old 12-20-2000, 06:44 PM   #12 (permalink)
POS,
The Chevy lights fit snug and I think look alot better than the Ford bubbles but this is just personal opinion. I just wired mine into the parking lights. Sorry it took so long to post but I have been on the road. I have put over 2500 miles on my X in the last 5 days.
Huck
Huckster is offline
Old 12-31-2000, 08:08 AM   #13 (permalink)
Got it done Tue. and Wed as promised. $258 with all the sales taxes and it really looks good. They didn't have the DRL relay as I supected and if I want one I'll have to go get it. Its 80 miles to the dealership so I may not and I may just wire them into the ignition switch..Anyone see a problem with that??
Curt
