Old 01-09-2006, 08:56 PM   #1 (permalink)
Rough idle when first starting
Does anyone else have a fairly rough idle when first cranking their Ex? Sometimes it will last for 5 minutes and sometimes longer. I usually have to push the throttle to the floor once and let a large puff of black smoke exit the exhaust before it idle correctly again. I thouhgt that it might have something to do with the air/fuel ratio but i really have no idea......any help would be greatly appreciated.
STR0K1N is offline
Old 01-09-2006, 09:05 PM   #2 (permalink)
FamilyRide's Avatar
Re: Rough idle when first starting
Part of what you're describing is as if you're talking about a gas motor, but I'm pretty sure it's not.
It would help to know more about what you have, what changed since the time that it didn't do it, etc. That would at least be a good start.
FYI, stabbing the throttle of a diesel when you first crank it up cold isn't the best thing to do. A diesel needs heat and needs to be driven easy if you're taking off while it's still prety much bone colda dn the EOT (oil temp) hasn't started coming up.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 01-09-2006, 09:38 PM   #3 (permalink)
It's a 2000 model with a 7.3 It had a banks powerpack, big hoss level 4 chip, k&n FIPK air filter, superchips micro-tuner, shift kit, muffler bypass, transmission, torque converter and a few other minor engine mods. I always let it warm up first before i do that with the throttle and i dont always have to do that to corect the miss the engine has...sometimes as it is warming up it will fix itself, but probably 2/3 of the time it doesnt. Between my dad and I we have over 30 diesels and 14 of them are powerstrokes. This is the only one that does anything like this. Thanks for letting me know about the cold start though.
STR0K1N is offline
Old 01-10-2006, 07:02 AM   #4 (permalink)
Is it extremely cold where you're at when it does this or does it do it all the time? Mine was like that in the winter until I switched to Delvac 1 (5w-40).
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 01-10-2006, 07:50 AM   #5 (permalink)
Could it be the EBV(exhust back pressure valve) sticking?? This is activated on cold engines to aid in faster warm up.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 01-10-2006, 11:29 PM   #6 (permalink)
I live in Southwest Virginia. Temps are usually anywhere from 22-45 when starting. We thought that the oil might be doing it, so we switched from 15w40 to diesel synthetic 10w30 and it didnt make much difference with that problem. It did however lower idle RPMs and quieten idle chatter.
STR0K1N is offline
