I htink there was a TSB on the rack isuebut the solution was to put a clear vinyl protective film on it. Either way, if it is the rack, you may have a chance to get some help with it from Ford. Is it rust on the surface? Or metal actuall rusted throuhg the paint?
there are only 2 pepole that make this disisjon in norway.
the local ford dealer said it was on warranty, but they dont have the
last word.
morten
thanks for the answers
You're in Norway so the laws are much different but to say becasue you haven't had regular service done my the dealer they will deny a warranty claim for a hole rusted in your roof, sounds like someone in Norway has been recieving packages from Colombia and consuming the contents. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
I would push it if it is indeed a factory rack that has caused a rust through the roof panel wihtout any modification.
Rereading above, I do not believe he stated it was rust thru the metal. Thus no warranty. I know the roof rack has caused many problems and you would think for would fix it for a reduced amount.
John [img]/ubbthreads/images/graemlins/smile.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
My bad. He said it was just through the paint. I'd be concerned that if it's the roof that's rusting through the paint, it's going to rust through soon. If it's the screw that rusted and the paint was compromised, After getting rid of the screw issue, I'd see if you could clean up the paint then protect it.
Without seeing it, it's a tough call.
I have a black 2000 X with 187000 miles, just a bit out of warantee. The roof paint has blistered in many spots and the paint comes off with the primer right down to metal.
Roof racks are off. The problem is all over the roof. It is my theory that since paint is water based the heat combined with black paint boils the existing water out the paint thus making it blister. The other explanation may be the roof flexing due to its massive size.
Ford says it is way out of warantee and will offer no help. I have been using rustoleum (sp?) and it will prevent it from rusting through.
Sorry should have got a pimp white vehicle.
Water based paint does suck. Paint adhesion failures is exactly why we went back to solvent based paint about a year ago in my shop at Boeing. Stipping parts is nasty-
"Pimp white" is what I bought and after reading this thread I'm glad I did.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
I have a black 2000 X with 187000 miles, just a bit out of warranty. The roof paint has blistered in many spots and the paint comes off with the primer right down to metal.
Ford says it is way out of warranty and will offer no help. I have been using rustoleum (sp?) and it will prevent it from rusting through.
I will bet your problem is excessive paint film build. Ford had to buy my truck back because of this same problem. The roof and hood of my truck was blistering right down to the metal just like yours. Upon further investigation we measured the paint with a Mil(paint thickness)guage. Ford specs for a paint job is between 3-5 mils. My truck had 12-17 mils [img]/ubbthreads/images/graemlins/eek.gif[/img] The only thing to do is a complete strip to bare metal and repaint. [img]/ubbthreads/images/graemlins/smokin.gif[/img] Double check the warranty. Rust thru is 7 yrs and unlimited mileage. Show Ford the bare metal and remind them of warranty maybe they will bend.
2005 F250 6.0 PSD CC Auto, Dk toreador red/Ariz beige,Lariat Luxury 4x4 SB,TT Mirrors,Camper PKG,Roof lights,ADJ pedals,REV aid,Trailer hitch,TOW COMMAND,ESOF,PWR rear window,3.73 posi,SIRIUS SAT radio. Built 08/09/04 2005 F250SIRUS RADIO
2002 BUYBACK bad paint F250 7.3 PSD Auto CC Lariat 4x4 SB, TT mirrors,Camper pkg,Grille insert,Hood shield,Tow pkg,Adj pedals,Shift on fly,Trailer brake,Spray in bedliner,Dk highland green w/tan. 2002 F250
