Old 12-26-2006, 12:54 PM   #16 (permalink)
JasonRandolph's Avatar
Re: rust
Just hooking up my Sirius that came for Xmas when I went to put the Antenna on looking at the roof the paint is all blistered and rusting.
Anyone get ford to help with the repaint?
I have an 02 with 60000 miles
2002 Excursion Diesel limited 4X4 V Code Front springs,F350 Rear Blocks,AFE Stg2 ProGuard7,MagnaFlow XL Exhaust 3.5DP, Helwig Swaybar, Bilstines F&R,285-70-16 BFG KOs on Stock F250 Rims
2005 F350 Lariat Crew Cab Long Bed
1999 E250 Work Van
http://community.webshots.com/user/thetiler
JasonRandolph is offline
Old 01-09-2007, 10:12 PM   #17 (permalink)
Re: rust
Cannot believe that no one mentioned the rust at the bottom of the door seams. Long story short Ford repainted my 99 F150 ext cab (all four doors and the tailgate) under warranty before I sold it in 01'. It was terrible IMO once the blisters popped (at the lower seam inside) it went downhill quick from there. That truck as well as our EX's and Super Duties don't have the bottom of the cab going under the doors to protect them from mud build up.
They pack with mud and filth and because of the seal unlesss you wipe really good it stays right aganist the seam.
My Trailblazer had the same issue just got repainted this year at 35K.
My Ex looks better just because of the protection of the running boards IMO. That said I cleaned them well and waxed them knowing that they will eventually rust. VW and other companies line the inside of the bottom of theirs doors with a yellow snot like substance. My 83 rabbitts still had perfect doors after 20 years and 200K.
My 79's went over fifteen years without significant rust because the bottom of the cab prevent dirt from packing into the lower door seal/seam area.
Clean and wax em well.
02 EX PSD Limited
76 F150 soon to be 4wd rockcrawler
83 VW GTI SCCA ITB Rally car
01 YZ426F, 85 IT200
http://community.webshots.com/user/bjhous79
bjhous is offline
Old 01-10-2007, 02:19 PM   #18 (permalink)
Re: rust
Did you have to go through a ford factory rep or did the dealer take care of it on its own?
I put a few pictures of the roof in my webshots
Jason
1999 E250 Work Van
Old 01-11-2007, 09:12 PM   #19 (permalink)
Re: rust
I had a black 2000 model prior to my gold 2002, and the paint was cracking and peeling extensively on the roof. I had quarter size spots of rust in about a half dozen places with the cracking all over. It was severely cracked on the hood of the truck also, but no rust due to the fiberglass hood! I feel your pain, and good luck with Ford.
Ricky [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
2002 Excursion PSD 4x4, Rancho RS9000x's, V-Code front springs, Ranch Hand full replacement front end w/Warn 9000lb winch, Helo Maxx 8 Chrome 18x9, Nitto Terra Grappler 285/65/18, 4x2 rear window struts, Rockford 1000.1db, Rockford 900x4, Rockford HX2 12"(rear box), Rockford HX2 8" (custom front box), Clarion VRX-745VD, old school Rockford Components upfront, Kove 5x7 second/third rows, AFE Stage 1 Intake
rgarza52 is offline
Old 01-12-2007, 12:13 PM   #20 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
Re: rust
I removed my roof cross member bars ages ago to keep them from rubbing off my paint. I still had some rust spots in the front and back corners around where my roof rack long rails that stayed on my X where bolted in. I taped the areas off, sanded them down and primered them with white. You can't even tell there was rust anymore. No problems since so far. I did buy my X pre-owned and it is a 2000 so I knew there was no warranty for me so I just took care of it.
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 01-12-2007, 05:38 PM   #21 (permalink)
Re: rust
I'm not trying to be picky, but Excursions, like all Super Duty Trucks, have steel hoods. I've worked on too many of them.
'02 Excursion Limited 4X4 PSD- Helwig Rear Sway Bar, Bridgestone Dueler A/T Revos, Rancho 9000s, V-Codes, '03 Stops, F-350 Rear Blocks, Drilled and Slotted Rotors W/ Ceramic Pads, 4X2 Hatch Struts, Rear Air Deflector, AFE Intake,203* T-Stat and Billet Housing, HD-ELC (GO RED), Ford AIC, Jotto Desk , Sylvania Silverstars, '03 Badges, Wipers - 24" Front 17" Rear, Auxiliary Back-Up Lights, Reverse Sensor Alarm Override Switch
Dentman is offline
» Sponsor Links
»Garage Storage and Cabinets
