Yes, they do make the ride more harsh . No way around it . 5psi or 60 psi still very bouncy . When loaded they work well it just the unloaded ride that is really effected .
OK, so if the harsher ride of the Air-Lit bags is not an option with my Mrs. on her mommobile, to keep the Exercion's ass up while towing my 8,000 Lb travel traiel with a 1300Lb tongue weight, I should consider the 2inch or 4inch rear blocks while leaving the fronts alone?
Not that I paid close attention, but I did not notice the harsher ride with the airbags when they are low psi and the truck is empty.
Other options that won't affect the ride include WD hitch on your trailer. With that much tongue weight, you need something to beef up the rear springs, not just make it ride level when pulling. Plus, taller blocks will give it a jacked up look when empty. Bet that's not going to score well on the mom-o-meter either.
I would like to compile A code B code Data like I did for all the fronts but I have yet to see documented data on these like I/WE did for the fronts. So any one that has replaced the G codes with As or Bs please inform us!
Also I still do not know the rate of the A code
I know the Published rate of the G and B if I knew the ride hight changes I could verify the rates and arch height differences. Then once we have that a few times to get an average along with a few rear axle weights at time of measurment. Then I could predict the ride height change for As and Bs like I did for the the S T U V W and X codes [img]/ubbthreads/images/graemlins/smile.gif[/img]
Also looks like some changes were made in the 05 SD rears
Any one know what the new codes are??? I have not been able to find a document like this for the 05s
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
I actually like the fact that the rear end got a little stiffer when I installed the airbags. The rear was too soft for my taste.
WBPSD
Ya, nothing like a nice tight a....uh I mean rear end. [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Get a brake rite electric over hydraulic brake actuator and use a drawtite brake actuator in the truck. Surge brakes are already banned in several states for use on vehicles with abs brakes. I switched to the brakerite system 2 years ago and will never go back, I can stop much quicker with my boat or my buddies boats then any surge brake could ever do. also I switched to a Ruenel rear bumper that is rated at 15k without equalizer bars our stock hitches are only rated for 5k without bars but the brakerite system will allow you to tow up to the hitches limit of 11k because you can use equalizer bars.
some other things to note is that boats are usually heavier then the manufacture state as my 27 footer with an 8' beam loaded with fuel and gear weighs in at 7300lbs including the weight of the trailer and they at first put it on a 7k trailer only to have the bearing fail twice. after taking it to a commercial scale the trailer manufacture swapped out the trailer for rated for 11k
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
Thanks Bruce - This is the information I am looking for. I have access to a set of "A" code rear springs. I am just to swamped at work and home to put them on. I am wondering if it will be worth the effort. [img]/ubbthreads/images/graemlins/confused.gif[/img] Has anyone took any measurements?
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
Yes PLEASE MEASURE!!!!!!
And here is what I think is the best way, front or rear
Measure from bump pad to stop or top of stop on BOTH sides add together and divide by two, even if you are on slightly unlevel surface you should get it right on this way.
Measure before and after, weights vary especially in the rear.
Remember front 03 and up stops are about 1/2 shorter we think, I don't have them to know for shure as I put my own "03" stops on in early 02.
If we can get data on the rear spring changes I will add a "REAR" page to my now well used excel file.
Bruce
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
