Anyone had to replace the seatheater in an 2000 ? what's it take ?
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
no one ? I am the ony guy with a bad seat heater ??
Thanks, I searched some but I was looking for someone with specific 2000 EX knowlege on the subject. The threads I saw had some that were built in to the leather covers and it scared me to death.
2000 7.3L PSD Excursion
4" MBRP 409 Turbo Back
Hellwig Swaybar
Isspro EV, Overhead 3-Gauge Mount
300K and rolling right along
Ford AIS
6.0 Liter Tranmission Cooler
Thanks BM Steve, Good article ......that porsche55 guy would know but it looks like he signed off in 2007 and never came back
first you have to determine if its a bad control unit or the Elements themselves. The elements are like little blankets that sit between seat foam and cover and they are glued to the foam. One on bottom and one on seat back. At the bottom front of the seat there is a two wire plug and a four wire plug that lead to the seat heater control unit ( 2" x 4" black box ) you will have to check with ohm meter to see if there is a break in the wire in each blanket. The seat back is the 2 wire, just see if there is a break between those two and the 4 wire I would check between outside wire to closest inside and the same on the other two. If no break in those it must be control box. Mine still work so I'm just guessing on this. Good luck. " NEVER MIND read the next post and go there "
LOOSEWHEEL; That was great THANKS!! I don't have the problem YET, but now I know how to take care of it. I think I bought some time, about a year ago I swapped my 01 buckets for a pair of 05's I found at a junk yard. Seat skin are a differant pattern but the color is REAL close. I dont know why they would change the tone of TAN but they did ?
Perfect !!!! Thank you again LOOSEWHEELl ! Pulled back the seat cover and there it was. Just like it said ....jumper wire was cooked and crunchy.
I repaired the wire and the heater is back in service. The wife is happy
