Old 12-02-2001, 07:57 PM   #1 (permalink)
Service Engine Soon light on
Would appreciate some comments on the following.
This past Friday evening I reprogramed my 2001 PSD Ex with the Hypertech Power Programmer 3 (model # 41012) and it installed exactly per the instructions. No faults whatsoever. I could see the difference immediately, wow! Today I made a trip to Cincy about 100 miles and all was ok. On the return trip tonite the Service Engine Soon light came on going up the hill out of Cincy on hiway 75 south while accelerating to about 70-75 mph from about 60. Engine had been warmed up for at least 30 minutes. Stopped for fuel, reset the fuel computer and driving the remaining 30 miles to home the fuel computer climbed to a high of 26.2 mpg. I know this is wrong and feel it might be related to the SES light coming on. The highest the computer ever registered prior to the PPP3 being added was about 22 mpg. Even the drive to Cincy today the computer read around 18 mpg.
I will be contacting Hypertech in the morning for some assistance on this subject.
Zachary is offline
Old 12-02-2001, 11:23 PM   #2 (permalink)
Re: Service Engine Soon light on
The SES light probably set an over boost code related to the acceleration sprint you made.
The high mpg on the fuel computer is unrelated to the SES light, and you are see what we all see that have added performance chips of one sort or another. Basically, when a chip (or a PPIII in your case) is added, the mpg computer is wigged out. So you'll have to do your mileage computing with a calculator.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 12-03-2001, 02:20 AM   #3 (permalink)
I do not have a chip yet, however, I had problems with my trip computer reading strange stuff, high mileage, incorrect outside temp, etc., so I took it in to the dealer and they told me the connecting was loose and about to come off. I have not had any problems since then.
2001 X PSD XLT Dark Satin Green
Bubba2 is offline
Old 12-03-2001, 07:47 AM   #4 (permalink)
Zachary I had the same thing happen with me X and PPIII. Installed it and drove around Atlanta with no problems for about three weeks. Packed our bags and headed for a road trip to New England this past Fall. When I started to hit the foothills in North Carolina the truck started surging up and down the hills. SES light came on, so I pulled it over and slipped the program out. Light went off and everything was fine. When we got back from our trip, called Hypertech and they of course suggested that I reinstall before sending back, did so, that was back in Oct,no problem since.
2003 4X4 LTD Edition PSD Excursion Rancho 9000's, Hellwig swaybar, U Codes,; 2001 F550 4X4 XLT PSD Smeal 6T Pump Hoist; 2001 F250 CC 4X4 XLT PSD
anoxic is offline
Old 12-03-2001, 08:37 AM   #5 (permalink)
Zachary, I agree that it's probably the engine producing boost higher than the computer thinks is "normal" and setting the SES light. No harm done. The light should go off after maybe 5 engine start cycles. It's been measured that the cruise control is capable of sending more voltage to the computer than the go pedal, so sometimes the cruise control provides more accelleration/boost, and trips the SES light whereas your foot cannot. A fix to this is to install a zener diode to the MAP sensor to clip the voltage output so the computer doesn't "see" an overboost condition. Under warranty, you could just avoid using cruise in hilly country to prevent setting the SES light. You need to get rid of this stored code before the dealer sees it, otherwise they will suspect a chip and give you the warranty void dissertation.
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
shamuex2000 is offline
Old 12-03-2001, 09:16 AM   #6 (permalink)
Agreeing with what others have already said, the SES light was tripped by overboost due to your Hypertech reprogramming of the computer. I had this happen with my Western Diesel chip coming onto a highway from an on-ramp. The light eventually turned off on its own.
-Eric
'67 Galaxie Pics | '00 Excursion Pics
erlong is offline
Old 12-03-2001, 08:26 PM   #7 (permalink)
Thanks to all that replied. I did speak with Hypertech today and they basically stated that the cause was most likely a overboost when accelerating. I could uninstall the program and the light would be gone and then reinstall the program again. If it were to happen again they said to contact them and they would take the unit back and slightly modified the program to prevent this from happening. Also, they acknowledged that there is a glitch with the MPG computer calculating the proper mileage. Just use the manual method to figure out the mpg.
After 5 engine starts today the SES light did extinguish without have to de/reprogram the system. Yeah learn something new everyday!
Zachary
Zachary is offline
Old 12-04-2001, 11:05 PM   #8 (permalink)
Just a reminder, although the light goes out after 4 or 5 start cycles, the fault code remains stored in memory. It has to be cleared with a scan tool if you are woried about dealer service problems later.
Ferraris do not break down, They just sometimes stop to be admired [img]/ubbthreads/images/graemlins/grin.gif[/img]
1970 Brabham BT29 Formula B Race Car Blue/black
1999 Ferrari 355 F1 Berlinetta Red/Tan
2000 Excursion Limited 7.3 2X4 White/Grey
2002 Excursion Limited Ultra 7.3 2X4 White/Tan
2002 Mercedes CLK 320 Blue/Grey (wife's car)
Ferraridriver is offline
Old 12-05-2001, 12:00 AM   #9 (permalink)
The Hard code will clear after around 40 warm up cycle's
01 Excursion, Silver,Dual-Shocks Pro-comp 6 Lift, 35 BFG's, Fabtech Bumper,TTS Flip chip
http://community.webshots.com/user/dbook14
DBook is offline
Old 12-05-2001, 12:03 AM   #10 (permalink)
I have a PPIII and enjoyed the additional performance. I too have the ridiculous MPG readings. I was told by Hypertech to remove a
fuse and reprogram to correct the problem. No one has been able to tell me which fuse.
I had the SES light come on while pulling a 6k lb
trailer up and down the Appalachian Mtns at 75 MPH. This thing was moving. I had the PPIII installed for about two months prior to this haul with no problems. I removed the PPIII program, returning it to factory and returned it to the dealer. They told me I had an overboost code, along with "something else" they weren't familiar with. I contacted the guys at Hypertech, they asked me to send in the PPIII to program it for a lower boost. I'd rather keep the performance and
run a lighter foot while towing.
Sub
'01 Black Ex PSD Loaded. 295/75/16 BFGs on Weld Renegades, Hypertech PPIII
subscursion is offline
Old 12-05-2001, 04:50 PM   #11 (permalink)
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by subscursion:
Sub
<hr></blockquote>
You lucked out by finding a dealership that wasn't keen enough to figure out what that "something else" code was. Almost all (not all) chips and the PPIII leave a sort of bread crumb trail behind in the PCM, even though you remove it, there's some other codes left behind (memory failures I think) that indicate there's been a chip or PPIII plugged in. They could have voided your warranty on the spot.
The best advice for anyone running a PPIII or other single bank chip is to make sure and get a scan tool plugged in to erase all codes left behind before going into the dealership for service!!!!!!!!!!!!
As was stated, codes stay in the PCM unless erased by a scan tool capable of erasing codes. Unplugging the batteries in most cases wont do it either, all you manage to do is create another code that a savy dealership can spot and interpret as a total loss of battery power (why, they might ask), and even then, the code you're trying to erase, isn't, you just add more to it.
The chips that don't leave this trail behind are the 4 page chips. But alas, there's really only one company that is successful at making a 4 page chip that will work in Excursions, and also won't leave any electronic evidence behind that it's been there.
But to erase other DTC's, especially hard codes, you have to have them erased via a scan tool. No other method is foolproof.
H&N Turbo 6 Racing
Seviervile TN
My Photo Gallery
Old 12-05-2001, 07:53 PM   #12 (permalink)
Send a message via ICQ to coldair
Turbo who is that company that can make a f bank chip that leaves on trace?
thanks mike
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 12-05-2001, 08:20 PM   #13 (permalink)
It's in my sig [img]images/icons/wink.gif[/img]
TTS Power Systems.
H&N Turbo 6 Racing
Seviervile TN
My Photo Gallery
Old 12-05-2001, 08:21 PM   #14 (permalink)
Just FYI...if you don't have one of the "4-page" chips, look around for a dealer in your area who is an authorized Saleen, Rousch, SVT, etc. dealership. The dealership I go to laughed at me when I asked if they would void my warranty for merely installing a chip in my Excursion. The performance-minded guys are a little less scared of bolt-on modifications. Keep in mind that if you fry your PCM for whatever reason, they could always not warranty the replacement of it. The chip alone should not void the warranty on the engine or any other part of the vehicle...IMHO.
I've run a "regular" (non 4-page) chip for 40,000 miles without any problems.
-Eric
erlong is offline
Old 12-06-2001, 01:22 AM   #15 (permalink)
How is the TTS for towing a heavy trailer? What are the exhaust temps like on a long steep climb? What happens if I hold the pedal at or near the wall for extended periods? Does it affect shift firmness and shift points?
Who are TTS dealers?
TIA
Oley [img]images/icons/smile.gif[/img]
7.3L PSD Excursion LTD, Chestnut with Medium Parchment Int., 3.73LS, Hellwig rear anti-sway bar, Edelbrock shocks, Michelin LTX 265 M/S, PP III, Tricumulator spring set, & Sonnax modulator kit, Walker BTM, 3 pod a pillar, W/ Western Diesel gauges, Ram Air, & Turbo Brake, BD Pressureloc and Autoloc, AXD0, with LL #8, fuel pressure spring 86 PSI, Oil Guard by-pass, Firestone Ride Rite, Cyclone Power Fan
BRUTYUT is offline
