Old 11-21-2001, 11:44 PM   #1 (permalink)
Send a message via ICQ to JasonRider
Smoke?
Quick question.
I've noticed that my gas milage as of late has been decreasing..
The other thing is that if I ever need to floor it to pass a vehicle or something I get a lot of smoke out of the exhaust.
Any ideas?
Has about 5700 miles on it, changed the oil back at 4k.
Seems to happen wether I get good/bad diesel (usually get fuel at the same place since I bought it with 300 miles on it)
Thanks in advance!
Jason L
01 Limited 4x4 X. Green Satin Clear Coat, 7.3L PSD, TT Mirrors, 3,73 Limited Slip, A/T Firstones, Htd Seats, All Opts except Rear Ent System.
SuperFord Registry
JasonRider is offline
Old 11-21-2001, 11:56 PM   #2 (permalink)
Re: Smoke?
Fairly new to diesels myself, but I think your mileage drop might stem from a winter blend of diesel. I have read on this site that the winter blend will kill your mileage. I don't know what you usually see, but my 4x4 X gets about 14mpg average.
As for the smoke, I get it too. Black smoke= Okay. White smoke= Not Okay. One of the old hands here will pick up where I left off. [img]images/icons/laugh.gif[/img]
Matt
2000 Limited PSD Excursion 4x4. OC Exhaust Brake, Walker BTM Muffler, Heated Towing mirrors with Turn Signals, K&N air filter, Dual Hella air horns AND Freightliner truck horns, with 4 gallon air tank. 5% limo tint on all glass, PSD and 4x4 badges. Yokohama Geolandar tires with 2002 style rims
PSDinOKC is offline
Old 11-22-2001, 12:11 AM   #3 (permalink)
Re: Smoke?
Jason,
You probably got a tank full of some cold-weather blend now that it's dropping down into the freezing temps in MN. I frequent the same stations a lot and was just up in North Dakota over the weekend and have still be able to get straight diesel #2. My mileage has been staying consistent at 16mpg but will drop into the 14's during the winter while running the winter blends of diesel fuel.
As for smoke...
Blue smoke on a cold morning is normal. Black smoke on acceleration is normal (particularly if you have a chip, mine smokes like an SOB when it's floored). The black smoke means not enough air in the mixture between fuel and air. Again, completely normal.
My X is going to roll over 40k miles next week sometime and the mileage has been improving with its age. Don't get discouraged if your mileage drops during the colder weather!
-Eric
'67 Galaxie Pics | '00 Excursion Pics
erlong is offline
Old 11-22-2001, 01:25 AM   #4 (permalink)
Re: Smoke?
Have you changed the fuel filter?? I'd try that.
I change mine just about every 2 oil changes or I have performance and mileage issues.
-work truck 97 F350 XLT dually, PSD, down pipe, 5 speed, Alcoas, two 60 gallon transfer tanks, boxes and goosneck and bumper hitches;
-play rig 02 X Limited Ultimate, PSD, Good Year 305's on chromed aluminum ARW's, 90 hp superchip, magnaflow 4", egt and boost A pillar guages,
CorMan is offline
Old 11-22-2001, 11:57 PM   #5 (permalink)
Re: Smoke?
How clean is your air cleaner?
HTH
Oley [img]images/icons/smile.gif[/img]
7.3L PSD Excursion LTD, Chestnut with Medium Parchment Int., 3.73LS, Hellwig rear anti-sway bar, Edelbrock shocks, Michelin LTX 265 M/S, PP III, Tricumulator spring set, & Sonnax modulator kit, Walker BTM, 3 pod a pillar, W/ Western Diesel gauges, Ram Air, & Turbo Brake, BD Pressureloc and Autoloc, AXD0, with LL #8, fuel pressure spring 86 PSI, Oil Guard by-pass, Firestone Ride Rite, Cyclone Power Fan
BRUTYUT is offline
Old 11-24-2001, 12:23 AM   #6 (permalink)
Re: Smoke?
When I start seeing a lot of smoke it is time
to clean the air filter. I have the Western
diesel foam filter and it only take a few min to
clean and reoil it. I have to do this every 10
to 15 k miles. The fuel filter gets changed
every third oil change.
2001 X PSD Limited 4X4 times two. Estate Green His and Hers.
PSD #1 replaced transmitsion at 27k,Turbo ped O rings at 18k
PSD #2 Transmition replaced at 34K
WD air filter,Hellwig rear anti-sway bars, Monroe Reflex Shocks
NRA Life member, GOA. WB4ZWK
rodney0 is offline
