snapped front leaf spring. Best heavy duty replacement?
Okay folks, I jammed my brakes today and snapped a front leaf spring in 2???
I've read all kinds of various threads about spring codes and such, I simply need to know what spring to get, and possibly where to get it. A heavier spring, that may lift the truck a bit is highly preferred. Please help.
thanks Ty
2001 Ford Excursion Limited 7.3 Turbonetics Ballbuster Turbo Spearco Intercooler AFE Stage 2 intake 4" Exhaust Stacked Tuners V code front leaf springs
Dealer or a place that does lifts on trucks. I got my V and F codes from a lift place and they were new for half the price of a dealer. Call around, you could get lucky.
'02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads, IH CPS part # 1876736c91.
I just got new V-codes from Tousley Ford's online site. They were $129 ea. and shipping from MN to MI was only $45 for the pair, so $304 total. My local wanted list pricwe which was like 185-ish ea.
You can use two Vs or I used a U and a V to help level the truck
It helped but it still sits low on the left with the V code and that is B4 I put my 280# butt in the seat.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Double chech But I am sure the U code is the same # XXX-GA
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Is there a weblink for the Tousley ford web site?..When I check it it just seems to be a dealer site, but no online parts ordering info?..or did you just call them on the phone?
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip http://www.turbodieselregister.com/f...sion-redo.html
Deo
