After two times when the door locks failed I finally found the problem. The guys who installed my stereo cut a protective boot and never replaced it, the wiring harness rubbed for 2 years until it found bare wire. The first time the guy who fixed it shorted the system, this time I caught it before this could happen. The first time cost me over $400 and I remember the stereo shop saying they cover the installation for life, I took all the paperwork needed and they are paying me $447.00 for the first job. I am happy now and I should not see another problem with the door locks....I hope.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
That is some someone I may just touch my truck who was it??
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
It is a local stereo shop, Vandenberg Stereo. That is why I had them wire the truck, that and with the DVD I wanted it done right. It sure paid off. It was too bad they did not protect the wire better, even I would have done better than this. I would never have known if it had not happened again. The guy who fixed it should have seen the wire the first time though, it was very plain to see.
