Spare Tire Carrier - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-03-2009, 03:58 PM   #1 (permalink)
Spare Tire Carrier
This is what I plan on making here soon. I will be mounting a 35" tire on it and maybe a hi-lift jack behind it. What do you guys think? Comments and suggestions VERY welcomed!!!
I found several kits that will make up the wheel mount, latch and spindle. I am gonna try and brace the left side under the bumper cover to the main bumper support so when I open it fully it won't sag so much.
I snagged the picture off of ebay, didn't have a pic of mine from behind.
2000 Excursion Limited PSD 4X4 Green/Tan 5" Superlift Selectride, Bilsteins, 35" BFG A/T, 16X10 Eagle Alloys, 3.73 gears, 203 Thermostat Turbo back 4" Banks Exhaust, 5" tip, Superchips 1705 Power Programmer,K&N Cold Air Intake,DVD system and Audiovox LCD monitor, Custom Bumper,4 KC Hilites
http://community.webshots.com/album/321346005bpfSxB?7
jguzman75 is offline
Old 11-04-2009, 02:42 AM   #2 (permalink)
therabbittree's Avatar
should be nice... I plan on doing the same.. hopefully give some more room in the back for storage.. I want to make a different interoir panel that doesn't have the spare tire cut out too.i will be making plate steel front and rear bumpers.. take some pictures of how you build yours.. have you seen Cross Enterprises version.. ? Blank
EMS Offroad has a decent universal tire carrier kit too.. Tire Carrier : EMS Offroad, Custom 4x4 Fabrications
Thanks,
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline
Old 11-05-2009, 07:36 AM   #3 (permalink)
I like the idea as well. But, opening the rear becomes that much more work. Three doors is bad enough. Decisions.....
Beast is offline
Old 11-05-2009, 08:11 AM   #4 (permalink)
I want to make a pivoting or tilt down tire carrier ie you could lower the tire down to the ground and unbolt it on the ground.. and same with reloading it..i may mount a small boat winch to lift it..plus that way my wife could change the tire if needed.. because she isn't gonna be able to lift a 285/75/ 16 spare out of the back of the truck and or take one off a spare carrier either.. something to think about..I could do it, obivously... but if your spouse drives the truck ..thats something to think about..even picking up the flat tire and rim and putting it into the back of the truck would be a huge struggle for a small woman..so I hope my idea works.. I will post pictures when I do it..probably this summer though. I plan on one board air system too so a impact would be available too..should be sweet
thanks,
Deo
Old 12-18-2009, 05:33 PM   #5 (permalink)
Done.....almost. It still needs paint and a hi-lift jack mount and it will be done. I wanted to drive with it and use it before I paint it so I could modify it. I didn't get any progress pictures but it was pretty straight forward. The only thing I would not do again would be the receiver hitch. I purchased one from Harbor Freight and the 2x2 that fits in the vehicle receiver had tooooooo much play in it. I had already built around it so when I cut that piece off and added the same 2x2 that I built the unit from it fit much better. I would just weld a receiver tube underneath a piece of 2x2 and built around it. This is going to work but it would look much better the other way.
Please don't laugh to hard when you look at the pictures, this was a rough draft but serves it purpose and with paint I think it would look much better.
In the first picture you can't really see it but the driver side tail light is completly visable if you are directly behind me.
I had the 2x2 already so that didn't cost me anything.
The receiver tube extension was about $20.00 (use weld on next time)
Latch from MSC direct $53.47 shipped. 2,000 lbs. claping force
Hinge was a 3 point 1 1/8 hitch pin from Tractor Supply $3.94
Just a little cheaper than one that you could buy online
Spare Tire Carrier-dsc01891.jpg   Spare Tire Carrier-dsc01892.jpg   Spare Tire Carrier-dsc01893.jpg   Spare Tire Carrier-dsc01894.jpg
Old 12-18-2009, 07:54 PM   #6 (permalink)
Wow, excpet for the tire carrier your truck looks like mine. I even have the rack! Very cool. Does it rattle?
Beast is offline
Old 12-18-2009, 08:44 PM   #7 (permalink)
Which rack do you have? The tire carrier doesn't rattle at all, the tire is too heavy. Can you send pics of your truck? Where did you have your drive shaft made, I have always wanted to upgrade mine there is a small vibration on take off and under heavy acceleration. The ladder bars took care of most of it but not all.
Old 12-18-2009, 10:53 PM   #8 (permalink)
I have the 6" wilderness rack with a custom wind jammer to eliminate noise. I will try to take pictures someday. Of course my truck is all scratched up from off roading. I had my drive shaft made at Tom Woods
Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
This is actually my second. I thought I had a problem with the first one but didn't. Anyway I now have two. Too bad your not close by. I would loan it to you.
It would be really cool if you could figure a way to mount the tire on the left barn door.
Beast is offline
Old 12-22-2009, 02:27 AM   #9 (permalink)
I think you did a fine job given you are using the hitch. It is somewhat what I have planed but instead I am going to have the pivot hing welded to the actual bumper (aftermarket bumper like a IronBull etc..) That way its solid for sure and allows full weight use of the hitch. I like your as opposed to buying the one that is similar. I always prefer built to buy and you saved money as well. Now I know were to get the various parts from, thanks
TARM is offline
Old 01-06-2010, 10:58 AM   #10 (permalink)
dvldog458's Avatar
My Photos: (54)
Send a message via AIM to dvldog458
Very nice setup!
Any pics after it was painted?
2004 Excursion Limited 4x4 6.0L
BDS 8" lift, 2.5" shackle kit w/ 37" Nitto Mud Grapplers, 20x10 Jesse James wheels, SCT tuner (Elite Diesel) A-1 H-11 Head studs, Dieselsite coolant filter
dvldog458 is offline
Old 01-06-2010, 03:46 PM   #11 (permalink)
Weather has been pretty nasty the past month or so since I finished. I also found some problems with it, mainly that it collects water in the tube that the swing mounts to. It is getting in the area where it pivots on the other side of the nut. What I will end up doing is drilling a hole by the nut somewhere to drain it and fill it with expanding foam to seal the entire tube. It also kind of sags while open so I will try and attach it to the factory bumper somehow. If you take the tan cover off there is a hole in the factory bumper and behind that is the main support for the bumper. It looks pretty solid and I was thinking of welding a tab on the bottome and at the end of the carrier and somehow bolt it to that pivot point under the bumper. I will post when it is complete.
Old 04-21-2010, 10:08 PM   #12 (permalink)
dvldog458's Avatar
My Photos: (54)
Any updates?
