Old 08-04-2008, 12:18 PM   #1 (permalink)
Supporting Member
detroitfd's Avatar
Speaker sizes - components?
Just wondering what the front door sizes are on the Excursion. Looking to replace em, probably with component speakers...lookas like 5 1/4 according to Crutchfield, but not much fits.
Anyone use the Basslink or the like under our seats? Do they fit?
Anyone using compnents? How do you like em?
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ serviceable S&B filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - Exhaust : 4" Turbo Back (w/ 4" down pipe) Stainless Steel Magnaflow - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - Dieselsite HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 08-04-2008, 09:01 PM   #2 (permalink)
3 pair of 5x7 are factory. If u dont replace the head unit dont worry about components.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, DieselPower Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 08-05-2008, 10:32 PM   #3 (permalink)
Supporting Member
detroitfd's Avatar
Yea, knew that - already have DVD head unit.
Jerry
My PSD X
TOWING:
Old 08-05-2008, 10:35 PM   #4 (permalink)
Gumbeaux's Avatar
Basslink won't fit under the seat. I went with the Blaupunkt powered sub because it will. Sounds great. It's not overly powerful, but it fills in the lows nicely. All depends on what you're trying to get out of it.
2004 Excursion 4X4 Limited - All options except 2nd row buckets - 6.0 PSD - X Springs front and 4" blocks in the rear - 295/75R16 BFG AT's - Superchips programmer - Ranch Hand brush guard - Sirius Radio - Infinty speakers, Blaupunkt powered sub - Garmin GPS - ProComp shocks - Thule rack My Photos
Gumbeaux is offline
Old 08-07-2008, 06:27 PM   #5 (permalink)
Supporting Member
detroitfd's Avatar
Any idea why all the catalog stores show em as 6x8s? I see some speakers rated for either opening...
Also, I notice that there aren't many types of speakers that fit in the front doors. Just wondering some of the best choices are. I think I'll update the regular speakers before the bass.
Crutchfield also has listing for rear door, and rear door/mid panel. Are there multiple speakers in the door?
Jerry
My PSD X
TOWING:
Old 08-07-2008, 07:14 PM   #6 (permalink)
william_04_X's Avatar
you have 3 pairs of speakers...1 pair in the front doors, 1 pair in the rear doors, and 1 pair in the third row seat area...
the pair in the front doors are on the factory front outputs..the two pairs in the rear are on the factory rear output..
04 EB X w/03 PSD
Southern Nevada Power Strokes.Org
william_04_X is offline
Old 08-07-2008, 09:07 PM   #7 (permalink)
Gumbeaux's Avatar
6x8's do work. That's what I have in mine.
Gumbeaux is offline
Old 08-07-2008, 09:27 PM   #8 (permalink)
Supporting Member
detroitfd's Avatar
I might have to go w the 6x8s, but only 2 sets crutchfield has even fit in the front doors...a marine version around $199 and somke crappy $50 Sonys.
I really wanna go with 3 way speakers, cuz the factory ones suck.
Gum, what 6x8s did u use in the front doors?
Jerry
My PSD X
TOWING:
Old 08-08-2008, 07:14 PM   #9 (permalink)
Gumbeaux's Avatar
I went with the Infinity Reference speakers. 6822's I believe. Great speakers. Ultra clear on the high end, and with the sub, the low is filled in nicely. If anything, they're lacking some mid range. I only did the front 4 and left the back row stock. I may switch out the middle row back to stock and put the Infinity's in the 3rd row. The stock speakers seem to have better mid range and that might help fill it in a little.
Overall, it sounds great though, and much better than stock.
Gumbeaux is offline
Old 08-09-2008, 10:00 PM   #10 (permalink)
Supporting Member
detroitfd's Avatar
Hmm, I left wanting more mids with stock, so I don't wanna lose more mid yet. Too bad they're not 6x9, lots more options, and 3 & 4 ways too. Anyone try and cut and fit 6x9s?
Jerry
My PSD X
TOWING:
Old 08-17-2008, 10:24 AM   #11 (permalink)
i have 6" boston pro seperates in the the front and mid. in the back I have boston coaxles and I think there 6" as well but maybe 5.25's. I have a single 12 sub in the bacl in a box. I'm talking to a local stero shop to install two 10" subs in the rear doors.
2003 EXCURSION EDDIE B, 7.3 PS, 4" Magnaflow Turbo Back, BD-Power X Monitor, AFE Stage 2 and Edge Evolution. JVC DVD head unit with Boston Pro series speakers and Rockford Fosgate amps. Oh ya, AC power for the Blender
scrmn6guns is offline
Old 08-18-2008, 10:43 PM   #12 (permalink)
Supporting Member
detroitfd's Avatar
Well, I ordered a new Blaupunkt thb 200A today. I was told about it here, and found that it's now discontinued. The 200A has 70RMS watts of power, and the new 210A has 120RMS. While I'd rather have the 120, it's too tall to fit under my mid row seats. So, I found a new 200 and went for it. Should have it within a week. I'll be upgrading the front and mid row door speakers shortly too, still not sure what yet. Thinking about components up front and coax in the mid.
Jerry
My PSD X
TOWING:
