Old 08-27-2008, 05:19 PM   #1 (permalink)
Supporting Member
detroitfd's Avatar
Speaker wire colors for neg and pos?
Installing new Infinity 6822s, and I dunno what wire colors are what for the + and -. help!
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (w/ 4" down pipe) Magnaflow exhaust - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub
Awaiting Install:
ViAir 380C Air Compresser, ViAir 2.5 gallon air tank, Grover stutter tone air horn
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 08-27-2008, 08:43 PM   #2 (permalink)
I had the same issue. Set your volt meter to 2 volts DC, turn on the radio and probe the 2 terminals. If it shows (-) voltage your wires are opposite i.e. red probe to ground, black probe to hot, if it shows normal voltage your leads are correct.
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
S.S. HX(removed for now)
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
Landyot's Radius Rods
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges
'99 E350 Snake Oil Wagon, 200+K, doesn't burn oil, lives on the bump stops & has a hard life. Runs like new.
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
fastersteve is offline
Old 08-27-2008, 10:07 PM   #3 (permalink)
Supporting Member
detroitfd's Avatar
Guess I finally have to go buy one of those. I just have a test light righ tnow, which sucks.
Since I had the door panel off at work, I tried wiring both ways, and sounded the same. I only had a chance to get 1 wired (thanks FOMOCO for making the original speaker wire JUUUST long enough to reach the stock terminals...I had to extend mine), so I figured I'd know the correct way to wire em when I put the other 3 in next week, and I can recheck the first. Thanks!
I put in a Blaupunkt 220A powered subwoofer and one of the Infinity 6822s so far, can't wait to hear it with all the 6822s.
Jerry
My PSD X
Awaiting Install:
TOWING:
Old 09-25-2008, 12:18 PM   #4 (permalink)
Supporting Member
detroitfd's Avatar
I finally got around to get the tester and try it, but it didn't quite work.
I'm going to get a different tester today, as the one I had only had 850m and 1.5v, nothing for 2v. But, in either setting, it showed negative both ways! Perhaps it's a bad meter or just because I didn't have the 2v setting? Ideas?
Jerry
My PSD X
Awaiting Install:
TOWING:
Old 09-25-2008, 09:17 PM   #5 (permalink)
Shouldn't make any difference 1.5 or 2. 2 is the lowest setting on my meter, output showed up as .3 so....try a little more volume.
AIS w/ sleeve
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
'91 Spec Miata
Old 09-26-2008, 11:39 PM   #6 (permalink)
Supporting Member
detroitfd's Avatar
I think it was just the tester. I bought a new one that was digital and it worked great. MAN those speakers are better than the stock ones.
Jerry
My PSD X
Awaiting Install:
TOWING:
Old 09-27-2008, 11:22 AM   #7 (permalink)
Yeah. I put the Infinity 6812's in mine, now my wife complains the stereo in her car sounds like junk..
FS
AIS w/ sleeve
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
'91 Spec Miata
» Sponsor Links
»Garage Storage and Cabinets
